Other What's ruining your life right now?
Discussion in 'General' started by TheMusician, 28 Oct 2009.
  1. adidan
    25 Mar 2009
    Really sorry to hear this.
    It is a personal choice at the end of the day. When my kitty got ill, started not eating and not keeping anything down when she did, she was slowly wasting away.
    After trying various things over weeks we were left with the option of letting her go or putting her through another trip to the vet to be put under for scans and further investigation.
    The vet said she would probably not survive that and vet trips always stressed her so in the end we had to let her go. Fortunately there was a travelling vet who came out so we could be with her at home, this was all around best for her but heartbreaking for me.
    It's just awful, I don't think there's a right or wrong choice. You know your doggie best and have to do what you feel is right.
    It's just painful. Hell, it's been over a year for me and I'm still welling up about it writing this.
    Hang in there bud.
    d_stilgar and sandys like this.
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Many moons ago, some friends of mine faced the same with their dog (Cancer in the snout).
    Their solution was to adopt another young pupper for the current one to train up as a successor.
    Isitari, Idioteque, d_stilgar and 3 others like this.
  3. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    The Zyxel NWA90X access point.
    It can get in the sea, I’m buying UniFi.
  4. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    What Issues are you having? These a very good AP's!
  5. teacherboy
    teacherboy Part Carbon/Nylon/Bovine
    29 Jan 2012
    I have (from the last 2 years) Grand Mal epilepsy, at 6.16am yesterday morning I had a seizure, wife gave me the sedative (Clobazam - a benzodiazepine) the neurologist had given me (and should take for 5 days) on top of my max dose of Lacosamide.
    Was a bit drowsy (Post seizure clobazam), couldn't speak properly and communicate easily because I bite my tongue during seizures, wife called NHS 111 due to worry that I've had a second brain bleed, she talks to them and while I'm speaking to them, I had a second seizure - off to the hospital for me for another CT scan.
    Thankfully clear!
  6. Byron C
    12 Apr 2002
    Nothing… now.
    But this morning it was having a right old fit.
    I tried creating a new SSID for 2.4GHz only and dropped that band from my “normal” SSID. It worked fine for a while… then the 5GHz SSID disappeared from all my devices. Then the AP rebooted itself. Then it reported as being online in Nebula but none of my devices could find either the 5GHz or 2.4GHz SSID. Then 5GHz worked… briefly. Then I reset my changes, set my regular SSID to all frequencies, killed the 2.4GHz SSID, and it rebooted. Then it worked, briefly, until it applied a firmware update, and rebooted again.
    Seems to have been stable since then. I wanted to upgrade it anyway, because it tops out at around 650Mbps - even when in the same room as the AP and running an iperf test to a wired machine. The reason that’s a problem is that I have a 1Gbit connection and I wanted to go to 2Gbit… But the only 6GHz WiFi6E device I have is my work MacBook; I’m not sure it’s worth upgrading to WiFi6 with 160MHz WiFi6 channels, or WiFi6 with 2.5GbE backhaul, if I can’t get the benefit in the devices that need it the most.
    Pookie likes this.
  7. sandys
    sandys Multimodder
    26 Mar 2006
    I used to have wifi6 160Mhz APs (well still do in a drawer) worked well always 1Gb connection for me, 1gb LAN port so that was the limit but if you are going 2Gb then you’ll definitely want the 2.5 at a minimum, If you are doing any mesh bridging that can take advantage of new standards even if you don’t have many wifi 6 devices yet, in time they will likely come.
    Problem with 160 is you can be fighting for channel space in congested areas in 5Ghz band, so whether it would work for for you is very much a suck it and see, same goes for 6E with the 6Ghz band, it doesn’t have the penetration so depending on where you need wifi, this could be an issue, for me it meant multiple Aps rolled out around the house preferably with wired backhaul, though when it does work it is blazing fast on a Wifi 7 mesh bridge for me across floors I have seen upto 6Gb via wifi to NAS.
  8. mi1ez
    mi1ez Modder
    11 Jun 2009
    Caused a P1 incident yesterday. Cloudformation stack containing the decommissioned proxy servers also contained the default route for the subnet. Took out our news website (38M requests per day) alongside a couple of others.
    MLyons likes this.
  9. Pookie
    4 May 2010
    Well is does say "Destroyer Of Things" on your profile :grin:
    MLyons, Idioteque, mi1ez and 2 others like this.
  10. Byron C
    12 Apr 2002
    Do you even work in tech if you haven’t killed something really important in Production at least once? :grin:
    This is actually quite a good indication of how healthy the working culture is at any given company. People are going to make mistakes - I’ve done it myself, I’ve taken down Prod databases that have killed a live site, wiped databases in the wrong environment hours before launch. The important part is how those issues are handled. The good ones will get the issue fixed ASAP, understand what happened, and try to put processes in place to avoid the same mistake again. The not so good ones will point fingers, blame, and bollock people.
    Still doesn’t make you feel any better about it though :grin:
  11. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    THIS! I was wiping our old development and testing copy of the website at the end of the day, ready for a new copy to be made. So I issued the delete command and merrily sat back in my chair as the last 5 minutes of the day ticked down. I then clocked where I was actually deleting; the production website. Stopped the delete, restored from backup, and still left almost on time!
    I changed the process the day after to avoid future incidents and the owner was more than satisfied.
    Gareth Halfacree, sandys and adidan like this.
  12. adidan
    25 Mar 2009
    I think it applies to anything to be honest.
    The real test of a company, workplace, hell, any sort of relationship, is how people handle things when bumps in the road come along.
    Everyone can be great when everything's going according to plan.
    Pete J and sandys like this.
  13. sandys
    sandys Multimodder
    26 Mar 2006
    Stuff happens, I have had a few in my time, just own it, learn from it, try and put process in place to stop it in future, move on :)
    Worst I can remember is ‘someone’ ;) creating a custom bondpad to reduce parasitic on RF nodes and missing the critical layer to put a cut in the Passivation….the bit that allows you to electrically connect to a chip from the outside world, that is a few mill for mask costs and a 6 month cycle time…Doh.
    Gareth Halfacree likes this.
  14. m0o0oeh
    m0o0oeh Modder
    20 Dec 2006
    My parents. As per usual, only this time they're actively demanding that I fix something on *their* car before I borrow it to go away for a weekend and if I didn't fix it by 3pm today the trip was off despite the fact that the car I'm planning to buy is sitting in the drive, screw the fact that I have trouble sleeping, sod the fact that they scrapped my car making me rely on their stupid asses for transportation, all of that is "not relevant."
    **** the world I want to get off.
  15. Mr_Mistoffelees
    26 Aug 2014
    As soon as you can afford to, leave home...
  16. m0o0oeh
    m0o0oeh Modder
    20 Dec 2006
    Therein lies the trouble - I've paid rent every month since I turned 18 and wasn't in full time education (which is most of my life,) I don't have anywhere near enough saved to move out thanks to working a min wage basic-bitch L1 Tech Support role, nor do I trust myself to look after my meatsack with all the pills and therapy and **** going on.
    Whilst they can be ***** they do keep me on track with stuff like medication (I have self-destructive periods and don't take my meds or look after myself) and it works out on the whole better than when I lived alone so I just deal with it, except on occasions like this where I lock myself in my room and get ripping drunk
    Hex and Mr_Mistoffelees like this.
  17. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    I wish i still lived with my mother, enjoy it while you can.
  18. mi1ez
    mi1ez Modder
    11 Jun 2009
    Oh damn, it does too. This dates back to when I was a detroyer of electronics.
  19. mi1ez
    mi1ez Modder
    11 Jun 2009
    Had about 20 people hop in the incident, it got sorted quickly, and the only thing that's been said to me personally about the whole thing is that I was unlucky to be the one that stood on that landmine!
    IanW likes this.
  20. Pete J
    Pete J Employed scum
    28 Sep 2009
    What's the saying? Something like:
    "A person who has never made a mistake has never done an honest day's work."
    Well, I have many, many honest days of work behind me.
    MLyons, Isitari, IanW and 2 others like this.
