Other What's ruining your life right now?
Discussion in 'General' started by TheMusician, 28 Oct 2009.
  1. Mr_Mistoffelees
    26 Aug 2014
    Aluminium has little fatigue resistance and fractures readily. You must have been lucky with the particular composition of the alloy.
    mi1ez likes this.
  2. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    The issue with that, however, is that a large 4x4/SUV will weigh a hell of a lot more. Meaning your wheels will hit potholes with more force and momentum at the same speeds, increasing your risk of wheel damage.
    At this time of the year, with the roads in the state they’re in, I am extremely conscious of the fact that my EX30 weighs 1,980KG.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    Yeah, my family car is a 2.1 ton Volvo too, it used to have 22inch rims for 3months till I damaged too many tyres and cut my losses downsized to get chunky tyre wheel ratio much better for the offroading required on the school run.
  4. Pete J
    Pete J Employed scum
    28 Sep 2009
    Hmm. Since I have a couple of weeks, I'll call around. I remember getting an alloy straightened out on my last car, and you could visibly see the dent (on these ones you can't).
  5. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Meanwhile, roads in rural France:
    Pete J likes this.
  6. Mr_Mistoffelees
    26 Aug 2014
    Is it time for a ‘What’s Ruining Your Tyres’ thread?
    Pete J and Chin Tablet like this.
  7. sandys
    sandys Multimodder
    26 Mar 2006
    To be fair the rural roads are fine here too, as nothing uses them, it's the high traffic roads that have been subject to numerous rip ups for services etc and not properly repaired that seem to be falling apart at least around here.
    The circumference of my Volvo wheels alongside more refined suspension means you don't feel potholes, speed bumps or small children when you fly over them whereas my Up! wheels are like shopping trolly wheels in comparison and I drive around feeling the pain of any undodged imperfection.
    The solution is tractor wheels, feel no bumps :D Will the Up have enough power to rotate all that weight :D
    Entry and exit might be a bit inconvenient. :D
    Pete J and adidan like this.
  8. Mr_Mistoffelees
    26 Aug 2014
    I have suggested to my wife, that a Unimog with a camper body, might be a good idea for the Winter.
    Nexxo, Pete J, mi1ez and 2 others like this.
  9. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    To be fair, not a bad idea for the summer either. Stuck in a caravan traffic jam? Just go off road and avoid the jams altogether :hehe:
    Mr_Mistoffelees likes this.
  10. Cheapskate
    13 May 2007
    Big, soft wheels are great, but I can tell you the stress has to go somewhere. After 7+ years of major construction in the area, I need to replace my steering gearbox. I've snapped a ball joint in the past too.
  11. Mr_Mistoffelees
    26 Aug 2014
    You need a rock bouncer:
    adidan likes this.
  12. Nexxo
    23 Oct 2001
    Yes, but you can park anywhere you want.
    Byron C likes this.
  13. Byron C
    12 Apr 2002
  14. mi1ez
    mi1ez Modder
    11 Jun 2009
    People who pay $120 for gig tickets, then talk through the whole thing.
  15. RedFlames
    23 Apr 2009
    at least they weren't on their phone the entire time?
  16. sandys
    sandys Multimodder
    26 Mar 2006
    The pitfalls of buying random hardware from China and having a fault, life would be so much easier if I bought from a UK shop or even amazon that you can deal with.
    Short summary of my current cyclical support email hell trimmed to not bore you too much
    ME: I have problems with USB disconnections, suspect hardware fault, if I add USB power to ports things work, take power away things disconnect.
    Even provided youtube videos of problems under windows and linux to rule out stock response many give on support forums which is oh its windows use linux. :rollingeyes:
    Support response: please list devices you use, ours work fine
    ME: yes my devices are working fine in all other machines I have, at least 5 machines of similar spec USB/TB etc and I then list all usb devices that are having a problem which is everything down to a keyboard
    Note, my response where I had already answered all their question with all the listed hardware etc, is included in their response :wallbash::wallbash::wallbash: this is going to be a long drawn out process.
    Fortunately, it has many ports and also I discovered the adding usb power trick makes the USB4 ports work and once they are on they are stable but it is less than ideal, needs a proper fix.
  17. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    Pain. It appears to be a bad pain day today.
    Got some severe aching mixed with burning stabs across my lower back that then wraps around my right hip. Burning lines of pain down the front of my leg coming and going, and all this leading to restless leg in my lower right leg.
    Had a blister pop up on my calf that is now healing - my lower legs are a mass of weak scar tissue from a couple of bouts of cellulitis and scars from blistered mosquito bites over the year, and every so often one of the scars "lets go" and blisters again, the healing of which alternates between extreme soreness to touch and mad itching. They heal just fine, but I could do without the pain.
    Also got the startings of a headache on the way, but at least that hasn't just appeared and I can take something to hopefully knock it back before it really kicks off.
    Managed to get about 5 hours of sleep last night which is very unusual for me so i shall have the risk of dropping off during my lunch break again, endless fun.
    Oh well, time to pop the pills and get back on sorting things out for everyone again.
  18. mi1ez
    mi1ez Modder
    11 Jun 2009
    That's an assumption right there...
  19. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    My poor dogs prescription has been messed around royally
    Got it last Monday posted it tracked 24 Monday. Didn't get delivered till Friday *thanks royal mail* then the company who ship it rang me to say there is an issue what's the name of my vets they need to deal with it. My vets then of Friday emailed it to them. Today they said can't accept email will have to post it my vets have shipped it 2nd class and it takes 3-5 days to process. I've got 7 days left but we both go away Friday for a week.. my vets want £90 for 7 days of tablets I've gotten 90 days for 90 online.... It's a joke
  20. Pete J
    28 Sep 2009
    Wondering why Sam Altman is allowed to get away with it, when he's clearly Elizabeth Holmes levels of sociopathy.
    stephen0205 likes this.
