Other What's ruining your life right now?
Discussion in 'General' started by TheMusician, 28 Oct 2009.
  1. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Can confirm.
    I had a pre-loved 2004 Vectra years ago.
    5 months after buying the car, the belt snapped at 70mph and the whole motor chunked itself.
    Luckily for me, it was still under warranty with the dealer I got it from, so I had the AA stretcher it there.
    Luckily for them, it was 2000 miles under the 1st belt change interval (40k) Vauxhall recommended, so they dragged it to the main dealer.
    TL;DR - I had a hire car for a month (no courtesy available) while the car got a refurbished block with all-new giblets, all on Vauxhall's bill!
  2. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Run Away, gather a mob and hunt down whoever's great idea it was to use wet belts and flog them with one.
    Cam chains for the win.
    Byron C likes this.
  3. mrlongbeard
    31 Jan 2010
    That's a dry belt, a wet belt slowly disintegrates, clogs the oil pick up, starving the engine and turbo of much needed oil and other not so great party tricks, a curse on them.
    Byron C likes this.
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    It's an engineering marvel, designed to destroy the engine a week after the manufacturer's warranty expires; great if you want to sell new cars, terrible if you want a car that will last.
    Byron C likes this.
  5. Arboreal
    21 Jan 2011
    Timing chains are no panacea these days.
    Plastic guides wear and they tensioners are usually hydraulic.
    They're subject to the vagaries of oil cha ges at the right time and the right oil.
    One of my customers is a whizz with the dreaded Ford 1L eco boost engines and getting tidy youngish fiestas and foci on the road again that will last fine of tended right.
  6. mrlongbeard
    31 Jan 2010
    True enough, but still 1.37 million times more reliable than a wet belt, I vowed to only have cam chains after 2 dry belts snapped on me, it just boggles my mind that someone thought wet belts were a good idea.
    IanW, Byron C and Arboreal like this.
  7. Mr_Mistoffelees
    26 Aug 2014
    I’ve never read anything good about wet cam belts. Cost cutting taken a big step too far.
    IanW and Arboreal like this.
  8. Arboreal
    21 Jan 2011
    I can't disagree in the least.
    My diesel car that I bought 5 years ago even though I swore I wouldn't buy has had it.
    Collecting a petrol car with timing chain and proven reliability at the weekend.
    Hopefully cheaper fuel will offset the potentially lower MPG. However, I have been advised to buy E5 to minimise carbon build up on the inlet valves
  9. RedFlames
    23 Apr 2009
    ok now i see why c++ does people's heads in
  10. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    Yeah, so, I don’t want to scare you or anything, and it’s hard to judge someone’s level of knowledge… But these guys aren’t wrong:
    That’s the main issue with wet belts: the engine oil corrodes the belt, tiny chunks of belt to fall into the oil pan, those little chunks get slurped up by the oil pickup, eventually the mesh on the oil pickup gets clogged, engine and turbo get starved of oil… and nothing good ever happens when you starve an internal combustion engine of oil (or coolant, for that matter, but that’s a different story).
    Ford’s small 3 cylinder turbocharged “EcoBoost” (aka EcoBoom) engines are the most notorious modern example.
    You absolutely can mitigate against these issues, it just carries a maintenance burden: never delay an oil change, use specially formulated belts & oils, and keep the oil pickup clean.
    But don’t take the word of some random blokes on the internet, have a chat with the garage when you take it in and get a professional’s opinion :happy:
  11. veato
    veato I should be working
    15 Jan 2010
    Got the car radiator off. But have removed so many parts, screws, hoses and electrical connections I'm genuinely worried how it's going back together.
    Also Autodoc are taking ages to send my new part so it's going to have to sit there for a few days now. Wont be using them again. Part was listed as in stock. Hmm.
  12. Pete J
    Pete J Employed scum
    28 Sep 2009
    Grr. Hit a deer on the drive in this morning. Considering everything, the cosmetic damage isn't that bad, but will need to have the business estate's friendly car mechanic look it over.
    That'll teach me for thinking everything's starting to feel on track life wise.
  13. David
    7 Apr 2009
    Yikes. On the plus side, is your freezer now fully stocked?
    Pete J likes this.
  14. Ajbod
    Ajbod Minimodder
    12 Dec 2016
    You cannot take anything you kill on the roads, it's illegal, however the car following you can. so you need to work out a deal, they pick it up, and later give it to you, or share it.:grin:
    Pete J and IanW like this.
  15. The_Crapman
    5 Dec 2011
    Go get a drink (probably a stiff one), get comfy, popcorn at the ready....
    I had not heard any from anyone for some time, so on friday I called the hospital to speak to neuropathy, as advised last time I saw the nurse. Gett through to someone quite quickly, excellent. "you've probably not heard anything back yet because there's a 48 WEEK waiting list" :eyebrow: my immediate response was "oh ****" then quickly apologised which she took with a chuckle, and took my details to have a look. "Oh yes Mr Makin, I've got your details here, oh, well we actually wrote back to your doctors 10days ago to advise that because of our long wait times, they'd be best to get further tests arranged themselves and see if there's any other causes of the symptoms". Great, so they had over a week to respond or feed that back to me. So I call the docs, and this is where things escalate. Quickly.
    Try explaining the situation to the receptionist, that it's an ongoing issue and I just need the doc to talk me through what's going on. Receptionist says she'll pass the details on, but it might be 72 working hours, on a Friday. I explained that this had been going on for weeks and they've already had 10days in which they haven't responded to the neurology team or me. Then she starts with the a-typical lippy receptionist ********, we go back and forth about "72 hours" and "you've already had more than double that". And then I snap. Scream "you've already had 3 weeks", hang up, put my shoes on, and head out the door.
    I get to the doctors 5mins later, calmed considerably by the walk, find the receptionist gobbing off loudly in the back for all to hear. That did not help my temperament, but I saw to her "look, you've had 10days, this is my brain we're talking about, not a stuffy nose. I need to see a doctor now" she comes back with "oh they're all in surgery no one can see you", I say I can sit and wait for when they have a gap, but I need to speak to someone urgently. Cue more cuntish back chat, head goes boom.
    Lots of swearing and shouting in amongst desperate sobbing later, someone comes out and takes me into a corridor. I think she's centre manager or something, along with one of the docs and the nurse who's been treating me. More sobbing and desperate pleas for someone to tell me what's happening as the only person who's done anything for me is that nurse, I already have permanent nerve damage because one of their doctors kept telling me everything was fine when I was missing a price of mesh from hernia surgery, and I can't go through that again. I'm told they will not see me today, but I can make a formal complaint if I want. More swearing ensues, I'm told to leave or they'll call the police. So I leave with "fine, but I hope when you see me dead on the news later you feel great about what you've done" or something to that effect.
    I leave, make it about 30 yards before completing breaking down and sobbing uncontrollably for a good 10 mins or so. A couple of ladies came out their houses, offered me comfort some tissue and water, which was greatly appreciated. One of them said she'd had a similar thing with them and moved doctors, having to drive 15mins rather than walk 15seconds, which tells you a lot.
    I eventually get home, still breaking down into tears sporadically, and there's a loud knock on the door. It's the police. :jawdrop::duh: Again my response is "oh ****", mostly because Mrs crap (aka D.C. Crap) is gonna be PISSED I've had to let them in when the house is a **** hole. They tell me quickly that I'm not in trouble, but they've been called by the docs as they thought I might try and hurt myself. This is a huge relief as as far as I can remember I never once threatened anyone, even in the rage I was cautious not to even call someone a f'wit or anything, but when the red mist descends my memory often evades me afterwards, so was a relief.
    We have a good long chat, the guy I'm speaking most with understands that when I said "when you see me on the news dead" I meant purely from a medical reason due to their negligence, not that I was going to harm myself. After a good while and they're happy I'm not a harm to myself, they leave.
    I have to inform Mrs crap what happened so she can deal with the work situation proactively. She is not happy. Not angry about what happened because she's also pissed off about the docs being ****, more that it's just awkward at work and the house is a mess. I get a message from the docs on the NHS app. They have finally reviewed the neurologists response, have booked an MRI (although no date, time or location advised), requested an outpatient appointment and have arranged for me to see a prescribing optometrist locally that I need to call to book. So finally getting somewhere, just took a complete meltdown to make it happen.
    I left it then till Monday, sent them a message via the website, apologising for the incident, but requesting a formal complaint be logged. Also asked when&where the mri was booked. Got a response pretty quick that I'll be called to make the MRI appointment and they don't know when the outpatient appointment will be, but have requested it urgently.
    Saw the optometrists Tuesday, eyes are in perfect health, but outer muscles that move the eye are a little weak. Being referred for more tests. Also remembered in the course of that I'd order some new varifocal glasses over a year ago and still hadn't got round to picking them up, so did so, and had forgotten I still had £300 to pay, so that was a nice surprise :rollingeyes: Still, they fit really well and vision is great, not entirely convinced I needed varifocals, but hey ho.
    Called yesterday for MRI appointment today. Bit of a wait when I got there but being on my noggin I got to keep my clothes on, just lost the belt, glasses and pocket fillings. Radiologist was nice, had a joke with her before hand about having had a few before and quite liked listening to the techno (as MRI machines are loud enough you need earplugs and over ear protection and could well be a brutalist sub-genre of said techno), laughs all round, in the tube I go. Come out the tube and the tone and demeanor of the radiologist as contrasting as an x-ray. Sullen face, gentle sympathetic tones "you should get the results in 2-3 weeks, ok honey" she says. Bugger.
    So now I have that to dwell on for a few weeks before I hear anything. Suffice to say I am already not enjoying it. I could of course be reading far too much into this, but even as socially awkward as I am, I'm normally pretty sharp on body language. I really wish I wasn't.
    Idioteque, MadGinga, Pete J and 3 others like this.
  16. pete*
    pete* Just. Useless.
    29 Apr 2009
    Dear god I hope nothing like that happens to me. I don’t have the balls to shout at people in any real situation. Horrendous treatment that.
    What an escalation that they bring up calling police. Although it isn’t so surprising nowadays.
    Hope the scans are clear and not what you fear. :brrr:
    And I’ve just had a hernia done too, by a surgeon who screwed me up a bit from an Op 6 months prior. Just praying it’s fixed.
  17. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I really feel for you buddy, GP's are utterly awful, and such terrible gatekeepers, I've basically stopped going to them being I've had so many bad experiences its just exhausting! The NHS is lovely, if you can get access, the issue is that first step us utterly broken its awful and needs radical overhaul! Its one of the few domains I hope AI wipes them all out because they're paid too much for awful service, and I've experienced it multiple times at multiple GP's in different parts of the country!
    MRI's are defiantly industrial, I'm hoping Venjent makes a song with them soon, his one with grinding wheels is great! xD
    And try not to fixate on things too much, one thing at a time, don't start pre-catastrophising, I'm terrible for it too, and it does no good and is totally wasted energy!
  18. The_Crapman
    5 Dec 2011
    God speed sir.
    Thanks. The NHS is a great thing run by inept twozzars who do an exceptional job at making it awful.
    I got a fair bit to keep me occupied. I had my new desk to erect and the top to massacre chamfer and stain, but now Mrs crap has suggested that rather than putting a nice new desk in a tired drab office, that we decorate the room first. What have I got myself into :worried::hehe:
    Idioteque, IanW, Pete J and 2 others like this.
  19. Andersen
    Andersen Morally despicable and ethically objectionable
    25 Nov 2002
    Most GPs are useless idiots
    Prime examples from various:
    Refused to prescribe rizatriptan, migraine medication. Apparently all I'd get is ibuprofen. Pointed out I'm allergic to it which I wrote in known medication allergies when registering. "I can get you ibuprofen". Mate you trying to kill me?
    Same **** tried to push statins which I have a strange reaction to: intraocular pressure goes dangerously high. Dude... I'm not going blind because you want a kickback or something. Besides I solved cholesterol problem via dietary changes
    Several GPs near Preston Road tube were outright twats about monitoring DIY HRT. Some said DIY is illegal. One of the practices continues to text me about vaccinations starting with "Dear Mr. Deadname"
    Outright cancelled my HRT and completely blanked out on the issue when raised. Dude... I'm dependant on exogenous hormones for rest of my life you idiot. Did prescribe a glorious amount of co-codamol though
    Awful management of HRT, wanted to keep me at low end of female E2 reference range + stop progesterone and dutasteride. Nope, happy spot is at 600pmol not 370. I'm no stranger to DIY HRT so had to guide two GPs at the practice. Never stopped getting weird looks tho
    Claims my balance issues stem for peripheral neuropathy. Yup got that, arms and legs. Oh just a thing. PN doesn't cause whole body pins and needles. MRI shows numerous plaques in my brain + got the diagnosis so there we go. You're not neurology, you're a GP. Know your place bruv
    #4 is why I stock a minimum of two years worth of everything HRT and maintain a list of active grey market suppliers
    Current GP? Acceptable. Could do better in some areas such as booking appointments and actually blacklist one specific nurse from my care: loves to interrupt, talks over me and ignores a sizeable portion of what I say
    IanW and The_Crapman like this.
  20. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    Cellulitis... again.
    Got what I thought was the start of another dose of cellulitis on my right calf on Friday night. Then it went away, fine must've just been an irritation or something, the skin on my lower legs is screwed from cellulitis already. Woke up this morning with my lower right leg on fire, bright red and blotchy, hot, painful to the touch and itchy at the same time.
    Called 111 got a call back within a couple of hours, sent a picture of the glowing red goodness that is my leg (which I shall spare you all, you are most welcome...), doc looked at that and promptly sent a prescription for some lovely lovely flucloxacillin to a local pharmacy, Gave it an hour for all that to get sorted and welt and grabbed it. That whole process worked wonderfully, just REALLY wish I didn't need to have done it.
    4th time with cellulitis, 2nd time on this leg, the eternal joys of a compromised immune system. Hopefully got it in time to prevent too much additional scarring and nerve damage but we shall see...
