Hardware What's the best 120mm case fan?
Discussion in 'Article Discussion' started by Claave, 28 Sep 2009.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    V.nice.
    Any chance you can produce the stats for a Gentle Typhoons when you swich the wires for a simple 7v mod? seems a cost effective way to use them? might be a winner!
  2. Nelly
    Nelly EverQuest Addict, 10+ Years.
    13 Mar 2008
    Great Review but their is a few cheap as well as expensive fans that are good for price/performance.
    Any chance of adding these to the review as soon as can be done?
    Akasa AK-FN057 Apache : CFM 57, DB(A) 16
    Enermax Magma UCMA12 : CFM 69, DB(A) 18
    Noiseblocker BlackSilent Fan XLP : CFM 75, DB(A) 31 (Maybe others in the BlackSilent-Series)
    Noiseblocker Multiframe S-Series MF12-P : CFM 78 , DB(A) 29 (Maybe others in the Multiframe S-Series)
    Yate Loon D12SL-12 : CFM 47, DB(A) 28
    Yate Loon D12SL-12D : CFM 48, DB(A) 23
  3. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Simpler test would be to use the fans on a STANDARDIZED CPU cooler, and record the delta T of the CPU in question.
    Do it in a air conditioned room to maintain more equalized temps.
  4. lepre
    lepre Minimodder
    28 Aug 2003
    The "Airflow vs Sound Pressure" graph is a bit strange because of the logarithmic nature of the dB scale.
    Would be helpful to add the sound pressure in the airflow graph and viceversa.
    Anyway nice review, very helpful as always.
  5. Mythmaker
    Mythmaker What's a Dremel?
    30 Oct 2009
    I registered an account to post this lol.
    I'm quite surprised that the Scythe Kaze Jyuni Slipstreams are not included. 1900rpm, 110CFM with 37dBA, Scythe rated them an amazing 46% more CFM than the S-Flex G (1900rpm, 75CFM with 35dBA) with just 2 more dBA.
  6. CrayOne
    CrayOne What's a Dremel?
    1 Nov 2009
    > sound pressure (in dBA), which most people confuse with noise.
    You are right. I am confused.
    How full speed could generate less sound pressure than min speed ?
    May be "Sound Pressure" and "Airflow vs Sound Pressure" graphs have some errors.
    Example 1:
    Gelid Wing 12 FN-FW12-15-B (max speed) 24.2 dBA
    Gelid Wing 12 FN-FW12-15-B (min speed) 36.3 dBA
    But you wrote for Gelid Wing 12 :
    At maximum speed, it produced 51cfm while emitting an annoying tonal 36.6dBA.
    At minimum speed, it emitted just 24.2dBA
    --> min/max speed description has been swapped and value are not the same (36.3 or 36.6 ?)
    Exemple 2:
    Noctua NF-P12 (max speed) 22.9 dBA
    Noctua NF-P12 (med speed) 27.2 dBA
    Noctua NF-P12 (min speed) 32.8 dBA
    But you wrote for Noctua NF-P12 :
    ... the Noctua NF-P12 spins at just 1,300rpm ... speed can be adjusted... to 1,100rpm or 900rpm.
    At 900rpm, the NF-P12 failed to inflate the black sack, so its cfm would appear to be 6cfm or less.
    At 1,100rpm, it produced 18cfm and emitted 27.2dBA.
    At full speed, it shifted 34cfm but was a rather noisy 32.8dBA.
    --> min/max speed description has been swapped in graphs.
    Am I wrong ?
    Thanks
  7. CrayOne
    1 Nov 2009
  8. Zeali
    Zeali What's a Dremel?
    9 Nov 2007
    I just bought Sharkoon Silent Eagle 1000 120mm to compare them with Noctua NF-P12.
    I've had NF-P12 for about 2 years now and when i read your article i was disappointed with Noctuas performance so i wanted to give Silent Eagles a try.
    I tested the airflow against my hands and legs(not that scientific but enough for me)
    Noctua: Airflow was noticeable from 20 cm and the noise at 1300 RPM wasn't loud. After closing my case only thing i head was small sound of airflow
    Silent Eagle: I didn't notice almost any airflow when testing the fan from 20 cm. About the noise, i was truly surprised how quiet the fan was. I couldn't hear the fan from 10 cm away. After closing the case i could only hear tiny tiny airflow but that was probably my GPU and CPU fan.
    When Noctua NF-P12 was running at 900 RPM the Silent Eagle was quieter and probably had better airflow but when thinking of case with full of hot components my number one choice still remains as Noctua NF-P12.
    Bottom line. If you really want a quiet PC and don't have that many hot components i truly recommend Silent Eagle 1000 but for noise-performance my choice still remains as Noctua NF-P12 and i feel the test wasn't accurate on Noctua NF-P12.
  9. mooh
    mooh What's a Dremel?
    18 Nov 2009
    I have to go ahead and be a grumpy critic. I still think a better way to measure cfm is to measure the air velocity inside (and at then end of) a cylinder, effectively an air flow meter. First unrestricted, then apply perforated plates to the front and back of the cylinder to simulate the pressure drop caused by air restriction of typical computer cases.
    Guess you could do worse than blowing up a bag though, you could have used a water balloon. :rolleyes:
    Secondly, the "Airflow vs Sound Pressure" graphs are very misleading. A reversed hoover would score great. To get more accurate airflow-vs-noise numbers (if you have correct airflow numbers), you need to convert dBA to sone. Or better yet, put the the baseline 1 at 0.125 sones (approximetely 10 dBA) which is practically inaudible. The formula goes:
    percieved_noise = 2 ^ ((sound_pressure / 10) - 1)
  10. ehume
    ehume What's a Dremel?
    10 Dec 2009
    I wish I had read this article long ago. I wasted money on Scythe Flex fans - low cfm, loud noise. OTOH, I am well pleased with my Gentle Typhoon 1450. It quietly blows a nice amount of air through my Megahalems.
    I like your methodology better than the alternate: put the fan at one end of a plastic bottle with an iarflow meter at the other. Your results correspond better to my experience with several of these fans. Their results misled me into purchases I now regret.
    Now - you have done 80mm, 92mm 120mm and 200/220mm fans. What about 140mm fans? I put a Noctua NF-14P on my Megahalems, and it was slightly louder than an NF-12P on the cooler, and appeared to push about the same amount of air. This means the NF-14P will go on the top vent. But what should I buy for a second 140mm?
    So far the Gentle Typhoon 1450 puts the most air through the Megahalems with the least noise. I am waiting on an Ultra Kaze 1000rpm and will compare them.
    Thanks for the great work.
  11. tonschk
    tonschk Minimodder
    31 Jul 2008
    I agree Totally ....... " a few extra mm of plastic or a a few degrees of fin pitch can make a big, big difference "
  12. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Just a quick question. I am about to buy the Corsair H50, and I want some fans in push-pull config. I was looking at the Scythe GT's, since they seem to be the best, but can you recommend anything else?
    Might be a bit off-topic, but -^O^-
  13. A3DSAIL
    A3DSAIL mod simple
    24 May 2008
    Picarro, Check out the article on installing the Corsair H50 over at LegitReviews ( http://www.legitreviews.com/article/1025/1/ ) to see what results Shane Higgins got when he sandwiched the H50 radiator between a pair of Noctua NF-P12's in an exhaust configuration instead of the intake method Corsair recommends ( http://www.legitreviews.com/article/1025/6/ ). The Noctuas claim excellent air flow to noise ratio, but these bad boys aren't cheap. I found them at Moddersmart for $17.95 USD (Performance-pcs has them at $21.95, but their shipping was a couple of bucks less than Moddersmart).
  14. idontwannaknow
    idontwannaknow What's a Dremel?
    20 Feb 2009
    I actually think what you say is a lot more accurate than the results of this fan test. Instead of inflating a black plastic bag, what should have been done is to look at the change in system temps and CPU temps when each fan is installed into a case and onto a standard heatsink. In almost every other test that I've seen done like this the Noctua fans, especially the newer ones like the Noctua NF-S12B FLX, came out top or near top for keeping down temps. The Silent Eagle 1000 used to be top for these tests about 3-4 years ago but in more recent tests they can't really compete with the newer fans and so they end up in the middle of the pack.
  15. procrew45
    procrew45 What's a Dremel?
    14 Jun 2010
    You've got the best thing going here since Haagen Dazs icecream. Just don't let Goty tell us that 28 dB is quieter than 25 dB... It might sound differently. I've got 5 SFF21G's running at 1400 rpm's, and have good airflow through my case and through HR-03 GTX and H50, and the system is audiable but has a pleasant low toned note, though I am thinking about the typhoons.
  16. Ruskie
    Ruskie What's a Dremel?
    5 Jan 2011
    I know I've joined this thread late but this is a great insight! Thank you for testing and posting this! I have a question and I know u guys can help... I want to increase the static pressure going through my water cooled radiator. I have 2x scythe gentle typhoons 1450rpm new (bought these mainly for the low noise level of them) Basically I have figured out a way of diy mounting these in series with a tube in between as a spacer. What I want to know is the optimum length i should cut this length of tube at to get the highest static pressure out of it?
    I know
  17. Ruskie
    5 Jan 2011
    .....I know there is a bit of turbulence exhausting from the fans which interferes with the airflow. so a small 'spacer' between the fans I believe is recommended thus the tube spacer I'm proposing to build.
    It's going to be a chunky spacer but how long should I cut this thing??
    Admin.... Are you able to shed any light on this considering you have testing equip and a lot more knowledge and experience. I'm a first time poster.
  18. Ruskie
    5 Jan 2011
    Anyone still watching this thread?
  19. Ruskie
    5 Jan 2011
    Hello?
  20. Pughy
    Pughy Fancy a game of Starcraft?
    21 Dec 2010
    I have no idea about your question mate, I'd suggest just make a new thread in the hardware section.
Tags: Add Tags
