Hardware What's the best 80mm and 92mm fan?
Discussion in 'Article Discussion' started by Claave, 15 Oct 2009.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. binary101
    binary101 What's a Dremel?
    30 Jul 2009
    The hardware you use to cool your CPU. not cooler :)
  3. stonedsurd
    11 Mar 2009
    Nice. Also good timing, considering I might be needing some 80mm fans in the near future :)
  4. Kyocera
    Kyocera The Garden of Evil
    9 Sep 2009
    Now I have a dilemma. Modders HELP!!!
    Chassis: ATCS 840; on the floor of the case:
    -two Gentle Typhoon 1450rpm 120mm OR
    -two Antec Big Boy 200mm ??????? maximum airflow of course :D
    On the youtube Big Boy does not seem that noisy,...
    I do not wish to have a screaming PC...
    The goal is to cool two "395" Nvidias in the next year. Each should be a 420W monster.
  5. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    I know you can't review every fan out there, but given the concerns about noise & the comments on FDB being quieter, any chance of someone looking at the thermalright fans at some point?
  6. Baz
    Baz I work for Corsair
    13 Jan 2005
    because Quad-SLI has such a proven track record for being awesome....oh wait.
    Realistically, I'd say the bigboys if you can squeeze them in - they're very quiet at low RPM mode and shift a lot of air even on the lowest setting.
  7. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Yay! Yet another article I paid for!
  8. Kyocera
    9 Sep 2009
    I hope this Big Boy advice does not have the IGN vendetta inside. :hehe: :hehe: :hehe:
    yup, quad SLi has proven to be a havoc!! (a money ransacking one) :hehe: :hehe:
    I was eyeing the Hydra technology about this one; quad Gt300. The only unknown variable is if this works with a "395", since they join two processors on one card in a different manner,...
    I'm interested in BigBoy at the highest setting, your graph shows 38dcB; and I doubt that an ATCS840 with two of them would not be a Scream..
    Otherwise I'll buy two 120mm Silent typhoon 1450; (they have a really pleasant sound).
  9. matt.bungle
    matt.bungle Vase
    7 May 2009
    Being a ventilation engineer and knowing how much I like tinkering with my computer at home 'water cooled monter Icore7'.
    Fans are limited, ie electric fans have a maxium rpm, fans that are bigger move more air because of blades are larger but run at the same maxium rpm.
    Computer fans noise bassically comes from air movement and a little on friction, so depending on how big your case is could depend on the noise level. Basically if you have a small case, the air (vol=m3/s) through your machine is the same as a larger cased pc but the air in the small pc case travels through a lot quicker (vel=m/s) than that of the larger one.
    The point i'm trying to get acros is the fans tested are not in any case and the case sizes can affect the noise level.
    Anyway when your talking about noise/performance 'who cares' along as it goes like a speeding train.
    Tip: Bigger fan the better, more air = cooler pc
    Eeven better, go for water and don't be affraid of trying.
    Matt
  10. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Might as well just chuck your PC inside a refrigerator. Wait for wireless displays and decent wireless power, and you have your fridge cooled solution.
  11. SBS
    SBS What's a Dremel?
    6 Jan 2009
    No Xilence Red Wings? Really? :(
  12. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    I wonder if Noctua are going to read this? I have a few of thier fans and i'm quite dissapointed they didn't do too well.
  13. Horizon
    Horizon Dremel Worthy
    30 May 2008
    no, 140mm round-up?
  14. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    what about arctic cooling 9L ? 26.7 CFM @ 19.0 dB(A)
  15. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    nice article.. that antec 200 is kinda overkill =p
  16. DaTLiTe
    DaTLiTe What's a Dremel?
    26 Apr 2009
    reading all the reviews on the different sized fans im very suprised by the poor performance of the noctua fans. I thought they were highly regarded but i am now wondering what all the fuss is about?
  17. Combatus
    16 Feb 2009
    Yes case size and fan positioning can affect noise level but we're not testing cases here we're testing the fans so it's useful data for everyone and not just people with say an Antec Twelve Hundred
    I think quite a few people do care about noise performance when it comes to PC cooling. We're not talking here about an outside airconditioning unit, we're talking about a PC that will sit a few feet from your ear.
    Unfortunately as we've found, many larger fans available for PCs are not better than smaller ones.read this
  18. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. What's a Dremel?
    2 Aug 2009
    I have 2 Noctua fans push pull on my Noctua NH-u9b cpu cooler. My AMD Phenom II 550 x2 is overclocked from 3.1 to 3.9 ghz and it runs 40 c idle and never higher than 49 c during intense gaming multitasking or what ever. I was surprised by the test untill i saw the chart at the end Noctua amongst quietest and coolest running max speed. I'm happy with Noctua. but this review is great it gives me another brand to look for when i build my next rig.
  19. Toka
    Toka Minimodder
    19 Nov 2006
    Uh.....
    Get your fans, a case representative of the target audience (say Antec 1200).
    Put fans on case, put case in anechoic chamber.
    Report noise levels in terms of delta dB
    Thus you are providing a real world comparison between the fans, just like the boys and girls at bit-tech have been doing for years. edit for CPU coolers
  20. Otto69
    Otto69 What's a Dremel?
    6 Oct 2007
    Next up, a water block cooling test using an uncalibrated spit covered fingertip....
    I can remember when Bit-Tech was the source for VALID technical information. It's been going downhill since Dennis bought it.
Tags: Add Tags
