Cooling Whats the best cpu cooler for the i7 920
Discussion in 'Hardware' started by Marc1314, 26 Oct 2009.
  1. Marc1314
    Marc1314 Where PC's go to die.
    11 Sep 2009
    Hi,
    I want to replace the standard cooler with something that will let me overclock up to 3.6/8Ghz.
    I know that you cant go wrong with the Akasa Nero but the Arctic Cooling Freezer 7 served me well with my old PC so i'm also looking at the new v2 model especially at around £20.
    Money is a big factor in this decision but i dont mind spending a wee bit extra if it is very reliable and quiet.
    So what cpu cooler would you recommend based on your own experience?
  2. bagman
    bagman Minimodder
    18 Apr 2009
  3. Pookeyhead
    30 Jan 2004
  4. bagman
    bagman Minimodder
    18 Apr 2009
    yes but TRUE's do cost a bit more than £20 i thinck you will find
  5. Pookeyhead
    30 Jan 2004
    Indeed.... just in case his budget wasn't set in stone... I thought I'd throw that in there.
    I'd also recommend the Fenrir... again, slightly over budget, but sometimes, going that bit further yields great gains... the cooler market seems to be one of those.
  6. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    Got a titan fenrir, works great (and was fairly cheap).
    I was about to recommend the arctic freezer 7 then i re-read your post.
  7. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    prolimatech megahalem, if you can stretch your budget
  8. Pookeyhead
    30 Jan 2004
    That's not exactly cheap either :)
  9. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Nowt wrong with the Akasa Nero. CPC got a C0 i7-920 to 4GHz with one, as did I. Should do the D0 chips just fine!
  10. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    hmmm. yes
    i hear the Arctic Cooling Freezer 7 pro rev 2, is good value
  11. bagman
    bagman Minimodder
    18 Apr 2009
    yes but titan fenrir only cost £5 more TRUE costs £30 more
  12. Ravenheart
    Ravenheart What's a Dremel?
    3 Oct 2009
    @ Marc1314
    Check out this thread (12th post down) This build seem decent enough? and as you can see when you look at the screenshot I posted from the Core temp program that I've had the temperature as low as 26 degrees celsius using the Arctic Cooling v2 with an i7 860 and right now looking in my system tray it's showing the temp @ 28 degrees celsius, not bad for a cooler that only costs £18.39 from Scan.
  13. Pookeyhead
    30 Jan 2004
    I was referring to the prolimatech megahalem :)
