what's the best hard drive to get for my PS3?
Discussion in 'Gaming' started by ktmakwana, 31 Aug 2008.
  1. ktmakwana
    ktmakwana New Member
    31 Aug 2008
    so i need to upgrade the harddrive in my 60gb ps3, and would like it to be 320gb! any recommendations of makes or models?!?
    as far as i am aware, it must be the following:
    *2.5"
    *SATA I/II
    *5400rpm
    it can run on higher rpm's but prefer to stick with what is recommended!
    i am aware that samsungs are good but i believe western digital are best?! correct me if i am wrong!
    any ideas what to got for? under £60 would be nice:D!
    also, would consider a 250gb but depends on price difference between the 2!
  2. Krikkit
    21 Jan 2003
    Please don't double post (there is an edit button, and it's perfectly functional), and please make sure you put threads in their proper places in future. If you don't know a mod would be happy to help. :)
  3. Major
    Major Guest
  4. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    really, there isn't much difference. one is as good as the other. just grab whatever is cheapest.
  5. ktmakwana
    31 Aug 2008
    k, cool, thanks!
  6. ktmakwana
    31 Aug 2008
    anyone recommend any particular models?!?
