Whats the best HSF for a XP 2100+?
Discussion in 'Hardware' started by couzo, 13 Jun 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I am looking at getting the new XP2100+ what the best fan and heat sink combo for it I am looking for quiet running as well if poss??
  2. Will
    Will Beware the judderman...
    16 Jun 2001
    Alpha 8045 and a 19dBa Pabst fan......
  3. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    which papst fan is that??
  4. Will
    16 Jun 2001
    Thats the quiet but not silent 80mm...........26cfm.......couzo said quiet would be a bonus, and this is as good as you can get in terms of a blend between performance and noise. Pabst also do a 12dBa 80mm fan (so quieter but far less airflow) , but a gnat farting moves more air :D so its not really up to the task,
