Storage Whats the best way to look after a SSD
Discussion in 'Tech Support' started by joolz1, 8 Oct 2011.
  1. joolz1
    joolz1 What's a Dremel?
    4 Oct 2011
    Hi any info on instaling Windows 7 & pro's / con's of looking after a SSD plz would appreciate it ,)
  2. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Move the page file to something that's not the SSD - set the page file to a static size (always a good option) - don't defrag your disk.
  3. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    pagefile to a static size used to be ok, not so much these days, but i agree move pagefile to a harddrive, but if i remember rightly, win7 if it detects ssd will disable pagefile on the ssd
  4. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    Hmm I don't think so, I've just checked and I have a 6GB pagefile on my M4.
  5. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Surely Pagefile on an SSD = speedy PC?
  6. RichCreedy
    24 Apr 2009
    you are correct, oh and just found this write up, which states pagefile on ssd is fine
  7. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Page file will default to some % of your RAM, putting it on your SSD will just wear your SSD down due to more read/write cycles hitting it for no real reason.
    Page files themselves are a tad pointless now anyway as most systems have 6GB+ of RAM and if you run out of that you're probably doing something wrong :)
    Static pagefiles are a good idea as they stop fragmentation of the drive they're sitting on - the size of said static file should be calculated by using sysinternals process monitor and seeing how much it thinks it needs. Or, if running databases on your computer -> should be the same size as your RAM. I usually set mine to 2GB (static) and have had no issues, it probably doesn't even need to be that big but i'm too lazy to work out how big it needs to be ;) (16GB ram in my system)
  8. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    It pretty much looks after itself under Windows 7! Just don't stress about it too much and enjoy the great speed.
    Also and idea to run the 'Windows Experience Index' as that optimises settings around an SSD somewhat.
  9. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    Well....no.
    Pagefiles are integral to Windows and the many programs that are written to utilise them. They are very important for error reporting given no-one runs ECC or FB memory in their home systems. That's a good enough reason on it's own.
  10. joolz1
    4 Oct 2011
    Great thx very much for your comments guys niceone;)
  11. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    This thread contains much yummy info and explanations of ideal setups + how tos.
  12. joolz1
    4 Oct 2011
    Thx Neil ,)
