Cooling What's the 'Hyper Evo 212' of AM4 Ryzen?
Discussion in 'Hardware' started by oscy, 7 Jun 2020.
  1. oscy
    oscy Well-Known Member
    22 Sep 2011
    As in usually recommended, high value, cheap (it was £25 I think), quiet and does a helluva job.
    (Yes other than the actual new Hyper Evo 212 haha.)
    I know 212 has a lone AM4 bracket / brace upgrade, but good luck trying to find one.
  2. Vault-Tec
    30 Aug 2015
  3. oscy
    22 Sep 2011
    I went a few pound more for the 120mm Pure Rock, as it's easier to replace when the fan starts being noisy.
    For the same price on Scan it was a choice between that or the Hyper 212 Evo. I had the 212 last time and installing it was annoying as hell, and its fan started getting noisy eventually, so not exactly comparable to a be quiet fan.
  4. spolsh
    spolsh Active Member
    4 Feb 2012
    Unless they've changed things, don't expect the bequiet to be less fiddly to fit ! I think you made the right choice going for a 120mm fan version.
  5. Vault-Tec
    30 Aug 2015
    Sorry man I thought that was the 120.
  6. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    I have a brand new bracket in a drawer ;).
    Also its " no longer available" on the CM store but they sell this kit instead :)
    https://www.cmstore.eu/spare-parts/...-pack-new-version-with-am4-but-no-socket-775/
  7. oscy
    22 Sep 2011
  8. oscy
    22 Sep 2011
    Ugh, the clips are a bizarre mechanism. There's thousands of lost souls on YouTube comment sections looking for a video showing and explaining how to put them on. But now that I know, it should be ok. 2 fiddly screws is better than 4. Despite the fan being a bit askew it's still 15 - 20C less now.
  9. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I've installed about 20 CM 212/212 EVOs and I still get it wrong and swear a lot every time. I mean that's gotta tip you off that your design is dumb, when professional case builders still get it wrong every time.
    Or maybe I'm just an idiot, not sure.
