ok i have noticed a few things since the upgrade. one is that most peoples sigs are bigger than their posts and it looks horrid and it seems thats forums are loading slower too me.
It depends how long your post is JB. If you only make a short post like that one, then the sig comes straight after it, and there will be a gap left because your information down the side is on more lines than your post and sig together. If you make a longer post (like this one) then you'll notice there's no gap afterwards. I hacked my old vB2 forums so that the sig was always down the bottom, and any gap left would be between the post and sig. Not looked through the vB3 templates to do so yet though.
Errr... Did the "no avatar under 75 posts" rule get revoked or was that avatar given VirtualJedi? I dare a mod to get rid of VirtualJedi's sig so he stays true to his word .
