Build Advice What's wrong with my PC?
Discussion in 'Hardware' started by chewbaccas_nan, 24 Oct 2012.
  1. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
    So maybe after an hour or so of playing battlefield 3 (haven't tried any other games), I get really bad lag and stuttering and also the sound goes weird, like makes odd 'electronic' sounds almost like some sort of dubstep/dance song! Even if i quit and watch say a youtube video, it still does it!
    I'm playing at 1080p, lowest settings with a Q6600, 8800GT. I don't ever remember it being like this when it first came out!
    Any ideas? Possible gpu overheating? Driver issues?
    (I'm kind of hoping my PC is on its way out so I can build a new one!)
  2. aNuclearPidgeon
    aNuclearPidgeon Minimodder
    3 Mar 2011
    Most likely your 8800GT. Check its temps while playing then report back. Also try lowering the settings if you haven't already to see if it helps.
  3. Jay88018
    Jay88018 What's a Dremel?
    5 Sep 2012
    Your PC is totally f*cked. Don't even bother trying to fix it, just new build - you know you want to lol
    Seriously though, run bf3 while runnin software that displays your gpu's temps, just to make sure of that 1st, especially if its only happening after a session of gameplay. what drivers are you using for your card ? i think 306.xx is the latest line of drivers (not including beta drivers ), could try that as well. Otherwise.....wait for someone else to come along who can help more......or hit the shops :D Hope you get it sorted
    Edit : Taking 15 mins to post, then saying what someone else said before me makes me look stupid lmao
  4. chewbaccas_nan
    27 Jun 2011
    Its the lastest drivers :jawdrop:
    what software should i download to check temps?
  5. ferret141
    ferret141 Minimodder
    18 Oct 2010
    MSI Afterburner can overlay framerate, GPU load, temp and whatever else it's capable of monitoring onto your screen.
  6. chewbaccas_nan
    27 Jun 2011
    afterburner says my gpu is on average 75 degrees
  7. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Sell the ****er, fast, or bin it.
    8800GT is a Mayan relic now m8, UPGRADE BEFORE YOUR WHOLE WORLD EXPLODES!!
  8. chewbaccas_nan
    27 Jun 2011
    How can I sell it? Its broken lol! So the moment I have been waiting for for over a year, now I have an excuse to build a new pc :D
  9. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    8800GT, that gotta by under 4 years old. Get a partial refund my good man! :thumb:
  10. chewbaccas_nan
    27 Jun 2011
    How so bloggins? Its made by a company that I don't even think exists anymore, 'BFG Tech' or something
  11. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    If you do decide to get rid of it, I'm in the market for a cheap card.
  12. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Average temps are not useful in this case. What's the maximum temperature?
  13. Parge
    16 Jul 2010
    Err, also, you could try to uninstall the Nvidia HD Audio drivers. Sounds like they could be conflicting with your mobo drivers (by the fact that the audio goes into a loop)
  14. Jay88018
    5 Sep 2012
    Thats the one i couldn't think of, i knew there was something else, either that or ghosts in your psu which cause emi lol Sadly BFG did cease to trade, so your screwed for RMA ( they did offer 10 years in uk, lifetime in us warrenty ), which is a shame since i still have a bfg 8800 gts :( Msi is a great program for checking your gc, id also use HWmonitor, its more about showing temps and voltages, rather than the control AB gives you, but it will give you an idea of temps all over your system. Seriously though m8, i would just split your old system, get as much as you can for the bits, and new build. I went from a q6600 and a 8800gts system, to what i have now, and i cant tell you how much im impressed, with missing a few genrations of chips, the step up is immense, and as for ssd's....wow i never believed the hype before, but they are totally worth it.
  15. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Download HWMonitor and run it while playing Battlefield 3, as it will store the minimum, average and maximum temps of the graphics card, motherboard, cpu etc it's a quite handy piece of software for monitoring temps.
    I use it all the time, as well as Real Temp and MSI Afterburner for a complete temp monitor system.
  16. chewbaccas_nan
    27 Jun 2011
    maximum temps were 80 degrees.
    Yeah ill just end up getting a new a PC I think guys!
  17. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Likely to be a temp issue that causes the GPU to underclock itself. The Q6600 is pretty decent (no issue with mine @ stock speed, but I have an HD5870). The GF 8800GT is pretty aged now, maybe you could retim it, that could help lowering the temp if you never did it, but at least a GPU upgrade will help a lot.
  18. chewbaccas_nan
    27 Jun 2011
    Yeah I think I've held out for long enough!
