News WHDI chipsets now available from Amimon
Discussion in 'Article Discussion' started by Tim S, 28 Aug 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DougEdey
    5 Jul 2005
    I'd hate to see the DRM on those things.
  3. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    that's pretty cool. i can imagine we'll be seeing some rather awesome house-wide multicasting setups in the near future.
  4. iwog
    iwog Linux cursed
    14 Jun 2007
    thats what the 3gbs speed is for, 1gbs to send the data another 2gbs to send some continually evolving form of DRM
  5. samkiller42
    25 Apr 2006
    So we could possibly have 3gbs wireless for our PC's as well then, i would be able to send huge files over my network in seconds.
    Sam
  6. Fod
    26 Aug 2004
    it's probably very short range...
  7. Tim S
    Tim S OG
    8 Nov 2001
    30m
  8. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    not careing much for video but for norm wireless use be very good if it can out do norm network cable speeds been able to do 300MB/s over wireless be good (probly 150MB/s after overhead) i be very intrested if thay sold this as an norm wireless product
  9. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I have 1gbit wired cable in my house, and have no problems with it. devices are not wireless anyway, you still need powercables and cables running to speakers and htc, and htc to display and stuff.
    Unless the invent a zeropoint energy device that i can fit in a lcd/plasma screen. Only then you can say i have wireless display on the wall...
  10. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    interesting technology, sure hope that the neighbors cant hack the signal...
  11. Darv
    Darv Bling!!
    12 Aug 2002
    I'd love to have my LCD hanging off the wall with no wires attached to it, although at the moment I'm using scart and component etc as well. I'm probably going to cut a channel into the wall and then put all the wires through there, with a junction box at the bottom of the wall. Same result, although maybe not as easy :dremel:
  12. yuusou
    yuusou Multimodder
    5 Nov 2006
    I sure hope my neighbors have a signal.
  13. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    Hell yes I am. No longer would I need to buy 50+ ft. cables, especially an HDMI cable; imagine how much that would cost!!!! As long as this is within a reasonable price I will really consider this for later installations or upgrades.....
  14. airchie
    airchie What's a Dremel?
    22 Mar 2005
    This should make a centralised A/V server with several wireless displays around the home a much easier prospect.
    Rather than a fileserver with several PCs around for playing movies/MP3s etc over the network, you can have a single a/v server with a few of these wireless jobbies for transmitting to any output devices you want around the house. :)
  15. completemadness
    completemadness What's a Dremel?
    11 May 2007
    if you use something like mythtv you can have a backend in your nice big noisy PC
    and then your front end's can be those lovely epia boxes and stuff
    Its just a shame that the epia boxes are so dang expensive :(
Tags: Add Tags
