PSU When do you upgrade your PSU?
Discussion in 'Hardware' started by Otis1337, 10 Jul 2017.
Poll closed 10 Oct 2017.
  1. When the warranty runs out
    6.9%
  2. Less than every 5 years
    10.3%
  3. Less then every 8 years
    13.8%
  4. More than 8 years
    3.4%
  5. Wait till it goes bang!
    65.5%
  1. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Yeah it's 50% load for long life, even consistently underloading a big psu can have its problems.
    People seemed to go mad on cases and power supplies back in the day and bigger was always better.
    Things have changed and smaller, cost saving and efficiency is the tech fashion now.
    I did a online calculation, my system pulls aprox 450w, so another 850w would be perfect for me. Looking at leadex superflow II, but not decided on pulling the money trigger yet
  2. Vault-Tec
    30 Aug 2015
    I should be OK with my AX1200 for a while then lol.
  3. Omnislip
    Omnislip Member
    31 May 2011
    I think form-factor is a big reason too.
    If you might ever go SFF, why not get an SFX or SFX-L PSU now?
    (turns out the reason is short cabling!)
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I was also going to respond "when it's too big". Gone from ATX to SFX, looking at short FlexATX and distributed power (separate AC-DC and DC-ATX modules).
  5. TheMadDutchDude
    TheMadDutchDude Flying Dutchman
    23 Aug 2013
    I tend to change it when I have a major hardware change. I just like new smelling hardware. :D
  6. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    I think I've only owned four PSUs in the last dozen or so years.
    The first (brand lost to the mists of time) did about five years' service until it had to be replaced after experiencing spontaneous combustion (suspiciously, immediately after a house move). It was replaced by a stop-gap Antec non-modular effort, which was then replaced a couple of years later by a much nicer CM modular PSU of the same wattage. That continued to serve proudly up until a few months ago, when I moved to mITX and obtained a second-hand Silverstone SFX PSU.
    All of these units were 500W jobbies (although the SFX is actually 600W, but I didn't buy it for the POWA but for the form factor). So that's one change due to catastrophic failure, one on the grounds of convenience/cable management and one due to change in form factor.
  7. Dr. Coin
    Dr. Coin Member
    13 Sep 2013
    I still have a AT supply I use when testing peripherals. Within my systems I only replace power supplies in the event of failure or when I wanted a newer higher efficient model that was fully modular cable.
  8. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Generally its around every 5 years or so for me. Although my last power supply was replaced at 7 years old.
  9. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    When the old one dies.
    I bought my first KW PSU some years back, to replace an 850, and well. If it keeps working I'm not going to spend money on it.
  10. nimbu
    nimbu Active Member
    28 Nov 2002
    Option 5.
    Though tbh as I have downside and chopped about a bit I have ended up buying additional PSU's etc.
    Right now though I have the 600W SFX Silverstone one and a corsair RM650. Prior to the RM650 I was rocking an Antec True Power PSU which was awesome, just not fully modular. So I ended up picking up the RM650 (uber cheap deal off avforums classified). I only got the SFX PSU as I was making things smaller and needed that form factor.
    I used to really scrimp on the PSU back in the day (anyone remember q-tec?), but after a while I started to subscribe to the buy a decent one and it will last. I invested in a Tagan for a long time, then an antec Neo Power and then the true power and so forth.
  11. Behemoth
    1 Nov 2001
    I've seen people selling Q-Tecs on ebay calling them "Golden Gaming Power Supply" I had one, I think I was one of the lucky ones as mine worked for years even after I sold it to someone else. I suspect it has either died or been binned or blown up in spectacular fashion by now.
  12. Ljs
    Ljs Well-Known Member
    4 Sep 2009
    My HX520 is probably about 10 years old. I cracked it open a few years ago to inspect and it still looked pristine inside (not a spec of dust to be seen).
    I don't imagine I'll replace it unless it conks out.
  13. nimbu
    nimbu Active Member
    28 Nov 2002
    I still have mine too its in the shed somewhere!
