Electronics When is my PSU not enuff?
Discussion in 'Modding' started by mookboy, 20 Feb 2002.
  1. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    OKAY, Im a bit unsure about the whole PSU thing. My system is as follows:
    Athlon 1.4ghz
    gigabyte mobo ga-7dx
    256ddr ram
    herc 3d prophet 2 4500 grfx card
    cdrw
    dvd drive
    80mm case fan
    sunon 60mm as rear exhaust
    two case blowers (the small black ones)
    2xhd (one 15gig and one 3gig)
    I only have a generic 300w power supply. When should I be looking to get a bigger wattage? I have MBM5 but I'm unsure what I should be looking out for in terms of the voltages etc.
    Anyone help? I would really appreciate anything anyone can offer.
  2. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    I've run a lot more than that off a generic 300W.
    Only worry if the machine is crashing for no apparent reason, and you can hear the pitch of the system fans change as the load level on the CPU changes.
    I have a chieftec 340W, which would be regarded by many as a generic, but it is perfectly capable of handling my kit, listed in my sig...I have 5 PCI cards, etc....
  3. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Cheers! I was getting a bit paranoid after reading some posts, but what voltage should I be looking out for as a warning sign?
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    As Isaac said, your system stability is the first thing to go. If you can't cure system crashes by re-installing, etc, the psu may be struggling.
  5. Sargan
    Sargan What's a Dremel?
    20 Jan 2002
    i have an 250W PSU that i run this with:
    P4 1.5GHz @ 1.65GHz 512mb ram, Sparkle MX200, Maxtor D740X 80GB, Samsung Spinpoint 30GB, 3 fans, one cdrw and one dvd, i havent had any problems yet, may be that my psu can deliver 13 amps in 12V which is kindof much for a 250W imo...
