Displays When the house bell rings, the monitor ripples!!
Discussion in 'Hardware' started by isaac12345, 28 Sep 2015.
  1. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Hi all!
    I noticed a few days ago that whenever the bell of my house rings, a quick ripple comes across my monitor! It happens quite often when the bell rings. My house didn't have a ground connection until recently and I got that fixed. I also changed the power strip my laptop, speakers, monitor and 2 routers are connected but it still happens.
    Any idea why this may be happening??
  2. Lankius Maximus
    Lankius Maximus Minimodder
    21 Aug 2009
    When I had the fuse box replaced in my place I had to ditch my extension sockets for my PC (the extension had its own breaker) as the two wouldn't play nicely together and one would trip the other. The electrician told me this wasn't unusual.
    Does the monitor ripple when the lap top is plugged directly into the mains socket without the extension sockets and the door bell rings?
  3. Vault-Tec
    30 Aug 2015
    At least you know when some one is at the door ;)
  4. Digerati
    Digerati Minimodder
    19 Feb 2011
    Does it happen when the notebook is running only on battery? If so, then it is RF interference and not coming through the house wiring.
    How does your doorbell work? Many run off a 24VDC transformer, but many run wirelessly.
  5. isaac12345
    20 Jul 2008
    Good point! I haven't actually checked that. Will do and get back to you.
