Hello , Do you know where i can find UL1007 Wires to take them OnLine ? (Into EU ) Dont tell me the www.rapidelectronics.co.uk because the minimum order is 500 £. Also i found some online shops but they have only the 305m reels . Please help me , i need them to continue my Case Creation !!!! I Need them As Soon As Possible !!!! Thanks In Advance geobest
Why do you want that standard? It's a high-temperature (105C) grade, the ATX spec only calls for 85C wire.
Outside UK the minimum order is £500. I want that because all the power connection from PSU to Devices use these type of wire. ( All power wires i check are UL1007 , 18AWG , 300 VOLT , -40°C - 80°C ) Can i user sometthing else ? if yes please tell me. I need to make all the power connection from PSU to Devices Thanks again Geobest
I have only one old PSU and for the two cases i create i need 15m Yellow , 15m Red and about 30m Black wire !!!! Anyone know where can i order please help !!!
i check the site you write , yes i found the wires i need but there is a big problem !!!! They have only 305m Reels i need only 15m-30m from each one !!!!!! any other online shops where i can buy with the meter ???? Thanks again Geobest
You do not need wire like this - any reasonably thick wire will do. Just make sure it can handle the current - TBH anything but signal wire will carry a fair few amps.
I don't think many dealers, on or off-line, will sell that standard by the metre. Best bet is to try a motor spares & accessories place, the wire used in cars should be a good quality, come in thick sizes, and in lots of colours.
When i was making a server last year, i bought soem wires at home depot in 20' packages (i think) and it was the correct stuff.
jeez man Rapid is cheap buy does work, just check your basket afterwards. from what i see there is no minimum order and if you spend 30 E you can get free shipping? or something?
woops. i skipped that part and went to here "No minimum order value We do not have a minimum order value and delivery is free on all orders over £25 (excluding VAT) - UK Mainland only." but yeah right above it...
Hello again There are no minimum order value for orders inside Uk outside UK the minimum order are £500 GBP (ex VAT).
