Build Advice where can I buy this material?
Discussion in 'Hardware' started by Refugee, 7 Dec 2014.
  1. Refugee
    Refugee What's a Dremel?
    25 Aug 2014
    Sorry the title sounds a bit confusing but I need to buy some thing to stop dust getting into a pc, I have a small piece of the stuff, it's black about 0.25mm thick with 0.8mm diameter holes in it and it's made of a stiff material either pvc or a glass fibre compound.
    I need a large piece and I am getting no were in finding out who sells this stuff in UK.
    If anybody can help would be very appreciated as I feel as if I'm knocking my head against a wall.
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    I cant help on finding that stuff, but black ladies stockings or tights are a good alternative
  3. johnim40
    johnim40 Minimodder
    23 Apr 2009
  4. suenstar
    suenstar Collector of Things
    13 Sep 2009
  5. GeorgeK
    18 Sep 2010
    I've used this before and it works a treat
    Flyscreen Insect Mesh Material - £7 for 1.2m² of the stuff
    you can use two or three layers to really block off the dust if you want. I attached mine with tiny magnets I bought off ebay
  6. Refugee
    25 Aug 2014
    suenstar that is the stuff I need from moddiy.com, just wondered if there is any were in UK that sells the same stuff.
    I don't mind waiting just seems kinda stupid to have to order from abroad
  7. Refugee
    25 Aug 2014
    GeorgeK if it wasn't going to be visible then it might have been ok , but thanks for link.
  8. GeorgeK
    18 Sep 2010
    Not to worry - mine is all very hidden so it doesn't matter what it looks like! It is cheap and does the job well but is rather ugly :lol:
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
  10. Refugee
    25 Aug 2014
    Waynio looks interesting I think it will be some thing different to look at with the correct lighting behind it.
    So will give it a try and as long as I can get an air flow through the mesh copper or brass will certainly look good and it's not exactly expensive.
    Thanks for taking time to help much appreciated
