Where can I buy this product (or similar) in Europe?
Discussion in 'General' started by Lovah, 8 Jun 2005.
  1. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Hi,
    As you might have seen in my other thread, I'm looking into buying a new screen. And my decision fell between the Dell 20" Widescren (2005FPW) and the 20" Apple cinema display.
    Now I really had no choice as I wanted to use this monitor on 2 computers. And the apple display only has one input.
    Today I went to the apple store and was amazed by the quality of the applescreen. Its turly amazing. Although I must say a Lacie screen is much better (for graphical use, color).
    But to the point.
    Since the Apple screen is DVI only, I need some sort of switchbox for DVI. And I found the perfect solution.
    http://www.iogear.com/main.php?loc=product&Item=GCS1762&sec=viewall#display
    Now I would really like to know a price on these. And find a store that has them and ships them to Belgium. (In Europe).
    A similar product (DVI Switch) is also acceptable!!
    Thank you so so much,
    L
  2. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
  3. Nexxo
    23 Oct 2001
    http://atro.nl/product_info.php?products_id=5125
    There you are: the identical product sold in Holland.
    Google is your friend. Especially if you click "advanced search" and filter for Dutch language sites only (since they don't do countries, you have to do Dutch and French to cover Belgium), using the search term "DVI KVMP switch". ;)
