Electronics Where can i find this plug?
Discussion in 'Modding' started by Slim Slotloader, 25 Feb 2007.
  1. Slim Slotloader
    Slim Slotloader What's a Dremel?
    19 Feb 2007
    I have this screen:[​IMG]
    I managed to fry it:[​IMG]
    This powerplug needs to be replaced, any idea where i could get one?(Europe/Finland)
  2. unicorn13
    unicorn13 What's a Dremel?
    26 Feb 2007
    Connector
    Hi there,
    try this url
    rswww.com
    I think the part number you want is - RS Stock no. 342-1646
    Data sheet is available online, to check pin pitch
    regards
    Andy
  3. Slim Slotloader
    19 Feb 2007
    Looks like it could work, and not that expensive either if it doesn't :)
    Thanks
  4. h_2_o
    h_2_o What's a Dremel?
    24 Jun 2004
    and if that doesn't work you could always hack together a new connector from an old mouse and extension cable of sorts.
  5. Slim Slotloader
    19 Feb 2007
    Have to look into that, would always be better if i find a way to replace it without ordering new parts...i think i had one of those in a DVD/VHS player i stripped to become a PC for my sister, bad thing is i threw all the internals in the trash :duh:
  6. JazX101
    JazX101 What's a Dremel?
    27 Jun 2004
    Sure you can manage to make something that will do the same thing, or mod both connectors. nice metal plug/socket.....
    Jaz_knos
  7. Slim Slotloader
    19 Feb 2007
    Yeah would be good, but requires desoldering the male plug off the pcb, and it takes more solderingskills than i have...those spots are so close to eachother i'd risk damaging it beyond repair :sigh:
