Modding Where can I get 800 - 1000 grit sandpaper
Discussion in 'Modding' started by KMS-oul, 15 Oct 2007.
  1. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    The local DIY stores such as B&Q only seem to stock up to 300 grit sandpaper. Would hobby stores or auto stores sell this grade of sandpaper? Need it to lap my CPU.
    Cheers
  2. Otto69
    Otto69 What's a Dremel?
    6 Oct 2007
    Try auto paint supply stores.
  3. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    Auto shops and Hobby shops will have finer grades but it will tend to be emery paper or wet and dry rather than sandpaper. Sandpaper tends to be used on wood and emery paper or wet & dry tends to be used on metal and plastics so it depends on what your want to do with it.
    I would say that your local B&Q aren't doing a very good service if that's all they have, did you try looking in their car section or the decorating department? If you are just looking in the woodwork section then that might be why you are only finding 300 grit - or you could say to the Customer Service desk that you want some finer grade abrasives.
  4. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Is this any good to ya?
    Or there's this (230 x 280mm 1000 Grit Wet and Dry Sanding Sheet)?
    And the top product on this page, is a kit which includes 120, 240, 400, 600 and 1200 grit sanding pads - for just £1.97?
    The 600 and 1000 grit are available individually near the bottom of the page, if the kit is of no use to ya.
    Finally... there's a whole range of different grades (including 800, 1000 and 1200) available from here ;)
  5. andyl33t
    andyl33t What's a Dremel?
    20 Jun 2005
    halfords have loads of fine grit paper. i think they have up to 1500
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I got mine from the local DIY shop where they sold single sheets, bought 240, 400 and 800 for HS lapping. Chain shops tend to just have multi-packs, but you should get the finer grits at Halfords and other car DIY places.
    I've used 1200 grit, but it's overkill, you can wipe your arse with it.
  7. KMS-oul
    1 Aug 2002
    Thanks for the help folks you saved me the hassel of driving around town. Looks like Halfords is the first port of call. If i find nothing then those links you posted Hazardous should do. BTW cpemma thanks for that really painfull mental image:naughty:
  8. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    You tryed your local Halfords?
  9. LiL_MJ
    LiL_MJ What's a Dremel?
    4 Nov 2003
    not sure i would like to try that :jawdrop:
  10. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    I found this on the bay.
  11. Hazardous
    21 Jan 2004
    The OP would have a long wait before he could use it though, since he's in the UK, and that seller is from the USA :idea:
  12. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i dunno about the uk, but all the big hardware stores and auto stores have it over here. hobby stores generally don't have much.
  13. midge
    midge What's a Dremel?
    17 Oct 2007
    halfords have it
  14. Guest-23315
    Guest-23315 Guest
    Yep, Halfords. They have nice packs of different grits ect.
  15. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    1200 grit is basically toilet paper
  16. shadow12
    shadow12 I lie
    30 Sep 2007
  17. Geektechnica
    Geektechnica Minimodder
    11 May 2004
