Modding Where can I get a G1/4" Tap & Die Set?
Discussion in 'Modding' started by Guest-23315, 9 Oct 2007.
  1. Guest-23315
    Guest-23315 Guest
    Basically as per the title.
    UK only please and prefferably from a shop..
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    try hindleys.co.uk
  3. Guest-23315
    Guest-23315 Guest
    Doesn't look like they do them..
  4. nibble
    nibble What's a Dremel?
    4 Aug 2007
  5. Guest-23315
    Guest-23315 Guest
    I still couldn't find it!
  6. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
  7. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    This place is fantastic http://www.tapdie.com/
    I picked up a G1/4" tap, m4 tap and handle from them a little while ago and they were really helpful.
    You'll also need an 11.8mm drill bit to make the right size hole (they sell those as well).
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    What's a 'G' type tap/die? :confused:
  9. Javerh
    Javerh Topiary Golem
    5 Sep 2006
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Thanks, I never knew that and I've used them, though only the dies on pipe.
    1/2"BSP (Parallel) taps you may find at a Plumbers' Merchant.
  11. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    G¼" = ¼"BSPP is it not?
    You can buy individual ¼"BSPP for £6.00 each from here :idea:
  12. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Or a bumper bundle from Amazon for £19.
    BSP = British Standard Pipe, = BSPP = British Standard Parallel Pipe, = BSPF = British Standard Parallel Fixed = G
    BSTP = British Standard Taper Pipe = BSPT = BS Pipe Taper, = BS Conical Thread.
  13. Guest-23315
    Guest-23315 Guest
    Well, i've got one now.. Coolmiester was nice enought to lend me his...
    It also seems that www.cromwell.co.uk sell them too!
