Modding Where can I get PCB's to use in a mod
Discussion in 'Modding' started by Liquid Steele, 24 Apr 2005.
  1. Liquid Steele
    Liquid Steele What's a Dremel?
    11 Apr 2005
    In mods that I have done in the past I have wanted to incorporate some pcb panels into the project but I have had no luck finding does anyone have any reccomendations on where a person could obtain some junk pcb's for project work.
  2. rankie
    rankie What's a Dremel?
    12 May 2004
    PCBs are made specificly for a particular device so using a "junk" PCB is almost impossible, I suggest you go down to your local radio-shack and get the stuff you need to make your own PCBs
  3. g0th
    g0th What's a Dremel?
    12 Apr 2005
    You mean you just want a 'junk' PCB kinda for decoration, right? Not to actually build electronics on?
    Surely you can find something to dismantle :)
  4. Mattt
    Mattt Minimodder
    12 Nov 2001
    if you want them for decoration, then just find/buy a old mobo or two. and if you want to you can remove all of the componets (put it upside down in a oven for a while, and anythin thing thats left over desolder the standard way).
    there was a thread a short while ago with a guy who was making a mouse mat out of a motherboard with all of the componets removed.
  5. Liquid Steele
    11 Apr 2005
    Yes the PCB's were only for decoration only I have seen mouse pads keychains notebooks and a assortment of other items made out of the pcb's so I figured that there was somwone to buy this as a art medium.
  6. pr0xZen
    pr0xZen What's a Dremel?
    5 Nov 2004
    Figure "PCB decoration" : Fill up a picture frame with old RAM. Or even better, decorate your "work room" door with RAM. If you can get yourt hands on that much. That way, if you fry a module, you always know where to get a spare :)
    If in need of PCB for pracitocal uses, stripboard is usually a modest and safe way to go.
  7. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    Cool little kit here
    Maplins Linkey
    Credit goes to Sam for posting
    here
    EDIT: Ohhh i see your in the states. I think radioshack (not quite sure) is about the alternative for maplins.
  8. Liquid Steele
    11 Apr 2005
    that is a great kit I just ordered one
  9. monkeyville
    3 Aug 2003
    Glad it was of help to you :thumb:
