Electronics Where can i get..
Discussion in 'Modding' started by Shepps, 8 Jun 2003.
  1. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    Sum optical out sockets ? i dont know what their proper name is either, so searching for them my self is rarther hard :p. Im in the UK btw, but if ne one knows what there called ... :D There the ones u find on high end soundcards etc
    also optical in sockets as well :lol:
  2. Shepps
    5 May 2002
  3. BasicBubbleHJK
    BasicBubbleHJK What's a Dremel?
    4 Feb 2003
    if you dont want to shell out the cash, i made an optical out for my sisters MD out of a molex connector and a 660nm LED
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Rapid Electronics do some Siemens versions from around £3. You can download the Optoelectronics cat section from here. They call em fibre-optic emitters & detectors.
    If you're not sure what the abit needs, I'd check their newsgroups. Google Groups is your friend. :)
  5. Shepps
    5 May 2002
    there not what im after, thxs for looking thoe :clap:
    i'll have good search on google + google groups. thxs
    Shepps
  6. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    FYI they are called TOSlink connectors
  7. Shepps
    5 May 2002
  8. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Indeed, possibly the most humourously named audio component around :p I'm just wondering, I know the square ones are TOSlinks, but are the round ones too?
