Cases Where do I get a P180 front port assembly (original P180)
Discussion in 'Hardware' started by hamza_tm, 17 Apr 2012.
  1. hamza_tm
    hamza_tm Well-Known Member
    10 Apr 2012
    Anyone know where parts for this classic case can be found, in the UK?
    The antec website shows them as out of stock.
    The NCIX site in the US shows them as out of stock, but NOT discontinued.
    I've tried the marketplace/classifieds of various forums but no luck. Any ideas?
  2. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Contact Antec directly, via email, I've found them quite helpful in the past.
    JBond and Teelzebub like this.
  3. hamza_tm
    10 Apr 2012
    Did that too, no reply :(
  4. Itchy Rim
    Itchy Rim Member
    3 Jan 2012
    Buy a second hand one from eBay and strip it down for parts, there are regular listings of P180's and if damaged it is generally the side panels and roof that is damaged so you might get one cheap.
    Itchy Rim
  5. hamza_tm
    10 Apr 2012
    Thanks a lot Itchy, I have actually bidded on two so far, one went for £25 (included a PSU) the other £18
    I didnt want to spend that much then have £10 shipping on top just for the front ports :(
