Hi, Aside from the shops at high street like currys and pcworld, are there any other places which I should go to find a laptop? I need to replace my 5 year old Toshiba M50 laptop with a W7 laptop. I heard that dual screen laptops have been shown in CES. Any dual screen laptops out now? I'm looking for a high spec laptop with a long battery life and has at least 1024x768 resolution. Weight <5kg. Will use it to do work most of the time, photoshop, video editor, movies, games sometimes. But usually I have lots of apps, windows running at the same time, so any mundane task will need loads of power. I'm eager to get those dual screen laptops if there are any out now. Thanks for the replies.
Hi, New year, and I just wanted to check are those recommendations still true or are there better places/online links to buy laptops? Should I go with core i7 laptops? Thank you for the help
