Windows Where is Frontpage in Office 2007?
Discussion in 'Software' started by shaile, 3 Jan 2009.
  1. shaile
    shaile Go BIG or GO HOME
    21 Nov 2008
    I'm getting ready to build my mom a new computer and she is insesint on having Frontpage because she uses it for her classroom website. I am pretty sure I have her convinced on running Vista, but I am unable to find Frontpage in any Office 2007 setup, only Office 2003. Is Frontpage being called something else these days or has Microsoft completely done away with it?
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    it's now called sharepoint web designer, and is not bundled with any office suite.
  3. Glider
    Glider /dev/null
    2 Aug 2005
    MS should have done away with it...
    But AFAIK it's called sharepoint, as supertoad pointed out.
  4. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Tell her to have a look at the W3c's Amaya as its W3C complient and more inportantly free.
  5. quack
    quack Minimodder
    6 Mar 2002
    It was replaced by SharePoint Designer (as previously mentioned) and Expression Web. Both separate products.
  6. scimmy
    scimmy Minimodder
    17 May 2005
  7. Nexxo
    23 Oct 2001
    ^^^ Seconded. Frontpage has a very Microsoft-centered way of writing HTML. This means that the webpage often appears correct only on IE while in other browsers it may be FUBARed. Best stick with something like Kompozer.
  8. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    Do an advance install of Office 2003 and install Frontpage only.
    Otherwise you'll have to buy new software and she will need to adjust using that software.
  9. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Besides what i think of frontpage personally, it IS called Sharepoint designer now. unfortunately, it's sold separately, and doesn't come as "complete" as some other editors out there.
  10. Stig
    Stig What's a Dremel?
    21 Dec 2008
    Do not confuse Sharepoint with Sharepoint designer. Sharepoint is the DEVIL (I had to work with it at a previous job and it was nothing but a nightmare). If you want some webdesign software I'd recommend notepad, or if you're not quite hardcore enough for that, then Dreamweaver. Expression web I have no experience with but I think its more design oriented than Sharepoint Designer.
