Modding where to buy a g1/4"bspp tap??
Discussion in 'Modding' started by x06jsp, 2 Oct 2007.
  1. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    hey people just a quick question where in the uk(preferably online) can i get a g1/4" bspp tap??
    thanks in advance
    josh
  2. nibble
    nibble What's a Dremel?
    4 Aug 2007
    Here you go, 1/4" BSP Tap. BSP = BSPP BTW, the correct hole size is 11.8mm if you didn't already know.
  3. x06jsp
    2 Apr 2007
    ahhh was wondering if bsp was bspp thanks and the size no i didnt knwo that awesome cheers!
  4. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    That's a through-hole tap btw. If you need a blind-hole tap it has the cutting edges in a spiral configuration.
  5. x06jsp
    2 Apr 2007
    huh? i need it for tapping holes in tubing that i will be using for some reservoirs im making. if you can point me in the right direction for the kind of tap/tap wrench i need for this that would be great.
  6. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    a through tap, the one in the link, is the kind you need.
  7. x06jsp
    2 Apr 2007
    awesome thankyou! just to make sure it wont be going all the way through the tubing so will it still be a through tap that i need?
  8. Javerh
    5 Sep 2006
    Oh sorry about that. I should have stopped to think. You definately need a through-hole tap as you want to make holes in a reservoir wall etc. and not thread a hole in solid material.
  9. x06jsp
    2 Apr 2007
    wikid thanks for the help guys!
  10. nibble
    4 Aug 2007
    They're actually pretty hard to find in europe despite obviously being a british standard. Anyway have fun making the res', can't wait to see the result.
  11. Javerh
    5 Sep 2006
