Cooling where to buy a green led cpu fan
Discussion in 'Hardware' started by numanoid, 10 Jun 2012.
  1. numanoid
    numanoid Minimodder
    26 Apr 2009
    Hi guys, im after a cpu green led fan to cool an AMD x4 640, ive got the standard cooler fitted but want to change the fan for a green led one, any idea's where i can buy one
    thanks guys
    take care
  2. numanoid
    numanoid Minimodder
    26 Apr 2009
    bump anyone know ;o)
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I think its a 60mm on the stock cooler isnt it?
    Only one I can find thus far is this one
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    Does the stock cooler use a standard fan that you can just pull out and replace?
    EDIT: IMO your best bet is to either get a cheap aftermarket cooler with mounts for a standard fan, or to set up some green LEDs yourself.
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    If it's a flower type cooler, you'd probably be better off getting a new tower hsf where you can easily slap on your fan of choice.
  6. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I agree. Pick up something like a cheap TRUE and just slap two green 120 mm fans on it. While you can get 60mm LED fans; it's not really worth the noise or the cost, because it's still going to sound like an angry banshee in the middle of furious procreation at the time.
  7. numanoid
    numanoid Minimodder
    26 Apr 2009
    :D, i think it is 60mm, cheers guys, looks like a new heatsink/fan is in order....thanks for your help guys....oh and do the fans realy need the cpu 4 pin connection or will 3 pin be ok
    thanks
  8. .//TuNdRa
    12 Feb 2011
    3 pin should be fine. 4Pin just makes it easier for the Motherboard to accurately control the fan.
  9. feathers
    feathers Minimodder
    11 Apr 2009
    Some motherboards won't give you any speed control when u plug a 3 pin fan on the 4 pin cpu header. Although the header is designed for both 3 and 4 pin, often only the 4 pin PWM can be regulated so I recommend you search for a green PWM fan. I think Enermax make some quite advanced lighting ones with the appolish..
    http://www.enermax.co.uk/produkte/luefter/apollishvegas.html
  10. numanoid
    numanoid Minimodder
    26 Apr 2009
    Cheers guys, ill take a look
