Planning Where to buy acrylic?
Discussion in 'Modding' started by dave_c, 26 Oct 2009.
  1. USFORCES
    USFORCES I have a Dremel!
    6 Nov 2009
    £120 and £500 per 1m square sheet?
    WOW that's just crazy, Where I get mine it comes in 4x8ft. sheet and anything less than 4x4 sheet is considered scrap, I just bought two pieces 1/4in 4x3ft. for $10US... It's clear but they also have colored scrap but I only make reservoirs so clear is all I get..
    I've also got free scrap pieces from them that is 3in. thick which comes in handy when making some stuff.
  2. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I'd like to know where you get your acrylic from. I can't find any locally, and online I used to get decent prices on Ebay on scraps, but that has dried up.
  3. USFORCES
    6 Nov 2009
    There is a couple plastic companies not to far from me, maybe I should start selling it online, I'm laid off right now... Hmm How much did they sell it for?
  4. denis6902
    denis6902 deathbox
    28 Sep 2008
    dude, it all depends what your build is up to, if u really want ur case to be bullet proof go for 10mm acrylic, but i can assure you 3mm to 5mm are ace to work and strong enough too, ask for samples of 3mm and 5mm and you wont believe how strong they are!
    I hope your working out already in case ure going to go for 10mm, its going to be really heavy!
  5. USFORCES
    6 Nov 2009
    1/4in = 6.3mm is perfect
    5mm would be fine to but 3mm is to thin if you ask me I wouldn't use it unless it's just for a side window maybe.
