Where to buy CX400? Amazon's fake?
Discussion in 'Hardware' started by ubuntzer, 29 Nov 2007.
  1. ubuntzer
    ubuntzer What's a Dremel?
    29 Nov 2007
    I would really like to buy Sennheiser CX400 headphones, but I'm a little counfused about the prize. $100 is a bit much, so I searched amazon (http://www.amazon.com/Sennheiser-50...1?ie=UTF8&s=electronics&qid=1196362257&sr=8-1) and found that they are $79.99, but it's also possible to buy form inviduals (newfoundpowerinc and 80cent) for $47.99. Is it possible that the cheaper ones are fake? How to know if Sennheiser CX400 are fake or real?
    ˇ
    Thanks,
    ubuntzer
  2. Krikkit
    21 Jan 2003
    Well the way to tell is look around on other online stores - if $48 is significantly lower than all other prices for them online, you can either hedge your bets that they're fake, or just give up and spend that bit more on them.
  3. ubuntzer
    29 Nov 2007
    It's one of the lowest prices i've found. I would really like to hear some personal comments and opinions :)
    Going to buy something today. If someone knows some trustworthy shop or seller that sells cx400 for under $80 it would be great if you would share it.
