Cooling Where to buy (or have made) a large alu heatsink??
Discussion in 'Hardware' started by airchie, 15 Sep 2006.
  1. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Hi folks,
    I'm planning out my next mod in my head and I will need a large aluminium heatsink.
    I'm guessing around 30x20cm with the fins running lenghways (like in the pic).
    The pic shows a small number of very wide fins, I really want a large number of much thinner fins, just didn't have time to draw it properly... :D
    So where could I get something like this?
    I don't mind if its bought or made to measure.
    Thanks in advance for any assistance. :)
  2. airchie
    22 Mar 2005
    I had another idea.
    I could buy some aluminium box section tubular rods and cut them to the right length, then stick them to a large flat peice of alu sheet.
    So it would in fact end up like the picture above except the 'fins' above would be hollow.
    In fact, would that be better?
    Would it create a wind-tunnel effect with the hot air rising and sucking cooler air in the bottom?
    How could I stick the tubular section to the sheet and ensure good heat transfer?
  3. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
  4. airchie
    22 Mar 2005
    lol, yeah.
    It needs to have a flat back to it as its gonna make up the majority of the side of a (hopefully watertight) case. :)
  5. Nexxo
    23 Oct 2001
    Talk to Enak. He is a UK member who does CNC jobs to order at a decent price. He can make you something to your exact specifications. Find him on these forums.
  6. airchie
    22 Mar 2005
    cheers Nexxo, I'll seek him out... :)
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Making up a heatsink from bits of aluminium section creates lots of metal-air-metal junctions; even with AS in between it's very much inferior to a solid extruded or machined section. RS and Farnell stock hundreds of HS profiles, check out the ranges, RS go to 30 x 30cm.
    eBay's also worth a look, I've seen extruded section any length, cut to order.
  8. airchie
    22 Mar 2005
    Excellent, thanks cpemma!!
    I didn't like the thought os having the parts stuck on and really think extruded is the way to go... :)
  9. airchie
    22 Mar 2005
    Having a 'mare finding large extruded aluminium heatsinks on either site... :(
    Anyone able to assist?
    I'm sure I must be missing something obvious...
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    At RS, get to the HS pages (under Semiconductors) and use the size parameter filter on the RHS. I think Farnell have similar filtering.
  11. airchie
    22 Mar 2005
    Gotcha, I'll give that a try, thanks. :)
  12. pdf27
    pdf27 What's a Dremel?
    6 Jul 2006
  13. airchie
    22 Mar 2005
    Hehe, thank pdf but all I get is a session timeout.
    I'll look at the url you pasted though and should be able to work out your search params from it. :)
