Modding Where to find ... mounting posts
Discussion in 'Modding' started by unicorn13, 18 Jul 2007.
  1. unicorn13
    unicorn13 What's a Dremel?
    26 Feb 2007
    Hi all
    Sorry if post in wrong section.
    I have been searching for a while an cannot as yet find a supplier for some mounting posts.
    What I need (idealy) is a mounting post with a M3 male thread 10mm long a smooth round shaft 6mm diameter and 50mm to pass thru water block mounting holes (Asetek Acrylic) then 3mm female threaded socket 100mm depth at the other end.
    limited on tools so DIY not an option.
    Also 20mm compression springs 6mm I/D.
    You guessed it got an asetek w/b, contacted Asetek about a week ago but still no responce :sigh:
    Thanks in advance for you help if you can.
    And
    BTW. I'm in Hull, U.K.
  2. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Asetek will finally respond. They have good tech support, but they are agonizingly slow which is why I never buy from them anymore.
    Make sure to enter a trouble ticket (sounds like you have already done that) Than register in their forums. After a week, post in the forum and ask a moderator to "Flag your ticket for attention". They will finally get to it.
