a computer store? http://www.newegg.com just the matx case or a case and mobo or what you should be more specific
tauren12 needs to do some reading... Read through this http://www.pcstats.com/articleview.cfm?articleid=1444& Then start looking for cases http://www.newegg.com/Product/ProductList.asp?Submit=ENE&SubCategory=7&N=2000090007
Umm here... let me explain... You rip everything off the computer the parts till the metal frame is left witch holds the case together I just want the frams of a computer I want a box frame
Ah, so you want a bare case, its not a barebone pc since that would include basic parts etc. If you just want the framework, just go to your local dump, I'm sure you will find computers there which you can take/buy, rip it apart and there you are. Otherwise buy a cheap case (from newegg?) and remove the side panels etc.
