soz about the title, im too tired to think of the correct name.... i was just wondering if anyone knew where to get those big circular drill bits that linear used in his lovely article (server killa)... i need 80mm, and 120mm -- any ideas of cost? ill dremel probably, schools are wonderful, aren't they? cad cams, dremels, pilot drills, and bigger things.... hmmmm cheers **currently listening to the frog song** g2g, GCSE modular exam 2moz, and Braveheart is on...
Coolcasemods does them in the tools section: www.coolcasemods.com £15.34 for 80mm £29.15 for 120mm Hope this helps!
Amazon/Tool Crib has them in the full range of sizes. Any full-line hardware shop ought to as well. The correct term is "bimetal hole saw" if you're searching. DeWalt and Milwaukee make the good ones. You'll also need to buy an arbor (sold separately) to hold the saw in your drill chuck. I feel like a shop teacher some days :.
I have seen them at Home Depots in the states here. Of course they are in inches and you have to convert but oh well. Just about any larger hardware store should have them like linear said.
You can find hole saws at any major hardware or home improvement store. I wouldn't buy them from modding online stores because I have seen very high prices. remember you also need a hole saw mandril bit to use the saws.
hole saws You can find hole saws at any major hardware or home improvement store. I wouldn't buy them from modding online stores because I have seen very high prices. remember you also need a hole saw mandril bit to use the saws.
i just paid like 19$ for a 3/8" arbor and 17$ for a 92mm holesaw .... got em at lowes cause i didnt feel like driving all the way to home depot ...
I know I saw them at ACE hardware here, but I didn't notice the pricing on them 'cause if it doesn't fit into a Dremel I can't use it. I need some new tools. On a side note, can anyone suggest the best size bit to use for removing the rivets from the top of a Lian-Li PC-70. I could do the old trial and error, but I would like to not screw it up too bad.
