Modding Where to get this mesh sheet?
Discussion in 'Modding' started by wywywywy, 22 Jul 2016.
  1. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Hi all,
    Does anyone know where can I get a mesh sheet that is similar to the following images? (Don't need the indents)
    It feels like it's made of steel, because it's cold (unlike plastic) and hard (unlike aluminium) to touch.
    I thought it was wire mesh, but looking closely I think it's actually fine perforated sheet.
    It's hard to measure but I think they are 1mm holes with 1mm pitch?
    I have seen it used a lot in cases' ventilation, but have never been able to find a source to buy a sheet of it.
    It's for a case mod project.
    Thanks.
  2. Cheapskate
    13 May 2007
    Search "perforated mesh" in Ebay's metalworking category.
    MNPCTech
    McMaster Carr
  3. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Ah crap sorry I should have mentioned --- in the UK.
    But yea I've looking on Ebay but I haven't been able to find anything. The closest is large PVC fan filters that I can cut to size.
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Mnpctech ships to UK often, contact our sales direct, and include size of sheet needed, we may have small scrap on hand to save you in postage. Mention this post for quote, http://mnpctech.com/contact-us.html
    Honeycomb Modders Mesh Sheet
    is 22 gauge perforated plain steel. 1/4" hexagon holes with 9/32" staggered centers
  5. davvy76
    davvy76 Minimodder
    18 Jul 2004
  6. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Many thanks. I've searched Ebay, Amazon, Alibaba, Aliexpress, and TaoBao already. And I don't see anything suitable.
    BUT! I've found that I can get used speakers for cheap and use their grilles, which is mostly the right hole size and usually in black. Made of steel too. So I might just go down this route.
  7. davvy76
    davvy76 Minimodder
    18 Jul 2004
    Ah I totally forgot about speaker grilles. I made a vent on a project some time ago by using the grilles from some pioneer car speakers. The steel was really easy to cut, scissors would you believe :D
    Edit Like these:
    http://www.ebay.co.uk/itm/185mm-rou...018122?hash=item1ea13b034a:g:g-EAAOSw3ydVn6xo
    I cut what I needed and then flattened the convex shape out of it.
  8. mnpctech
    21 Apr 2003
    good suggestions :thumb:
