Graphics which 1?
Discussion in 'Hardware' started by t4n6o, 7 Sep 2011.
  1. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
    1280MB MSI GTX 570 Twin Frozr III Power Edition/OC, 40nm, 4000MHz GDDR5, GPU 770MHz, Shader 1540MHz
    or
    1280MB EVGA GTX 570 Classified, 40nm, 3902MHz GDDR5, GPU 822MHz, Shader 1645MHz, 480 Cores, DP/ HDMI
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You do realise you can add an actual poll to your OP :)
  3. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    I have an MSI GTX560Ti with that cooler and its awesome (in a well ventilated case that is) otherwise the EVGA use a rear exhaust fan which can be of help in cramped cases.
  4. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Go for the MSI
  5. Unicorn
    25 Jul 2006
    The one that doesn't have a number in place of a word in the title...
  6. MrGumby
    27 Apr 2009
    Not very constructive now is it Unicorn? Not a great title i will give you that but he didnt come on here to learn how to word a title.
  7. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    Definatly the MSI imo... better cooler :) however EVGA does offer life time warrenty... but lets be honest who has a graphics card for that long?
  8. GoodBytes
    20 Jan 2007
    The question is if the company will last a life time... I am looking at you BFG. Shame, they were good cards and had preaty good after sale service. No call to India, and everyone was relax and flexible, when I called to get my GTX 260 serviced (fan sensor broke, but since then my GTX 260 is holding very strong)
  9. t4n6o
    16 Aug 2011
    i did but when i swllected the option for 2 answers and continued it went as a normal post and when i tried to delete the thread and repost i couldn't
  10. t4n6o
    16 Aug 2011
    the case i am looking at is the Coolermaster HAF X, so would a rear venting fan like the evga be better or would the MSI be more than ample?
  11. murraynt
    murraynt Modder
    6 Jun 2009
    I'd go for the MSI. Looks nicer :p
  12. faugusztin
    11 Aug 2008
    @t4n6o: with that case where you have more holes than raw material it really doesn't matter which one you use, both will get plenty of airflow.
  13. t4n6o
    16 Aug 2011
    the MSI is cheaper than the EVGA by about £50 and as i understand however the clock speeds on the EVGA ar better exept for the memory clock:-
    MSI / EVGA
    Manufacturing process 40 nm 40 nm
    Cores 480 480
    Core Clock 770 MHz 822 MHz
    Shader Clock 1540 MHz 1645 MHz
    Memory 1280MB 1280MB
    Memory Bit Rate 320 Bit 320 Bit
    Memory Type GDDR5 GDDR5
    Memory Clock 4000 MHz 3902 MHz
    Cooling Dual Fan Fan
    Interface PCIe 2.0 (x16) PCIe 2.0 (x16)
    Connectivity 2 x Dual Link DVI-I,1 x mini HDMI1 x DisplayPort, 2 x Dual Link DVI-I, 1 x HDMI
    SLI YES YES
    SLI Type 3 Way 3 Way
    HDCP Ready
    Width Dual Slot Dual Slot
    CrossFire NO NO
    Crossfire Type
    Low Profile Compatible NO NO
    Low Profile Support
    Package Type Retail Retail
    Maximum GPU Power 219W 219W
    Maximum GPU Temperature 97 °C 97 °C
  14. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    I'd also go for the MSI. The GPU clock is higher on the EVGA model; however, with that excellent cooler on the MSI model, you'll be able to clock yours higher and remain cooler, regardless of what case it lives in.
  15. wyx087
    15 Aug 2007
    they are the same. go for the cheapest one.
  16. t4n6o
    16 Aug 2011
    right thats it i am going for the MSI
  17. Sentinel-R1
    13 Oct 2010
    They are clearly NOT the same....
  18. wyx087
    15 Aug 2007
    both are gtx 570. just different packaging.
    it's like asking which bottled water to get, end of the day, it's still water, just different packaging.
  19. Sentinel-R1
    13 Oct 2010
    I absolutely disagree with you matey. Yes, the GPU is the same but that's where it ends. The EVGA is a non-reference PCB and cooler but resembling stock, MSI is non reference PCB and much improved cooler... not to mention the difference in factory frequencies present in both cards..
    ..and it matters because whether overclocking or not, you'll achieve different results from each card be it performance or noise levels - with the MSI running cooler and quieter... so nothing like bottled water really is it :wallbash:
  20. wyx087
    15 Aug 2007
    well, since MSI has better cooler and is cheaper, win win? :D
