Which 2080ti??
Discussion in 'Hardware' started by j17ypr, 16 Jun 2019.
  1. j17ypr
    j17ypr New Member
    24 Apr 2009
    Hello
    Finally getting round to building my new PC, using a Silverstone GD10 case - https://www.silverstonetek.com/product.php?pid=489&area=en
    I'm restricted with the height of the case to 5.25". I won't be overclocking the card. I've read somewhere that I should probably be getting a triple fan card due to the cooling of the case. I've always had EVGA and been happy with their cards, but their cards that will fit are all 2 fan designs. The other one's I've looked at are:
    ZOTAC GeForce RTX 2080 Ti Triple Fan - https://www.ebuyer.com/858276-zotac-geforce-rtx-2080-ti-triple-fan-11gb-graphics-card-zt-t20810f-10p
    MSI GeForce RTX 2080 Ti DUKE - https://www.ebuyer.com/857820-msi-g...11gb-oc-graphics-card-rtx-2080-ti-duke-11g-oc
    Gigabyte RTX 2080 Ti GAMING OC + AORUS RGB 256GB M.2 NVMe SSD - https://www.scan.co.uk/products/gig...tracing-graphics-card-plus-256gb-aorus-rgb-m2
    Any recommendations on any of those cards? Or will the EVGA ones be ok? The EVGA ones I'm looking at would be the BLACK EDITION (https://www.scan.co.uk/products/evg...dy-graphics-card-4352-core-1350mhz-gpu-1545mh) or XC ULTRA GAMING (https://www.scan.co.uk/products/evg...g-11gb-gddr6-vr-ready-graphics-card-4352-core).
    Thanks!
  2. VipersGratitude
    VipersGratitude Well-Known Member
    4 Mar 2008
    I'd wait a month or so for Nvidia to release their "Super" branded cards, and either get one of those, or get one of the current ones you're looking at for a reduced price.
    adidan likes this.
  3. adidan
    adidan Avatar now in stock for xmas 2019
    25 Mar 2009
    Agreed, if you can hang on a little while it'll do you no harm at all - either in choice or price
  4. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    I wouldn't worry too much about the number of fans and focus on the results, when it comes to the coolers on the cards mentioned they can be split roughly in 3:
    High cooling performance and noise: Zotac
    Middle of the road: EVGA
    Tweaked for silence: MSI
    So where does the Gigabyte one fit? It actually manages to be the "stand out" by offering both good cooling and silence, making it the pick of the bunch.
    But as said above, Nvidia recently dropped some teaser about something "Super" coming... so might be worth waiting a bit.
  5. j17ypr
    j17ypr New Member
    24 Apr 2009
    Amazing, thanks guys. Itching to pull the trigger :hehe: I'll try and hold off then for a few weeks, and go for the Gigabyte
  6. BA_13
    BA_13 Active Member
    2 Sep 2011
    I have the MSI duke and I recommend it, nice and quiet and close as makes no difference in performance to the nosier cards.
  7. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    Hit and miss experience with all brands of cards, I'd consider the Zotac stuff assuming they still offer longer warranty periods, there's a weird issue with some of the 2080's (not sure on ti's) from EVGA with the fan motors clicking when starting up.
  8. jsbombjack
    jsbombjack New Member
    14 Mar 2015
    I have the standard gigabyte windforce 2080ti. Got it for £999.
    Has samsung memory, so haven't had the micron issue.
    Also, with a decent custom fan curve (achievable through the aorus software) it does not sound like a wind turbine. Though my ITX case does have sound dampening stuff which might help. Temps don't get higher than about 75c either. Recommended
  9. MLyons
    MLyons Half dev, Half doge. Staff Administrator Super Moderator Moderator
    3 Mar 2017
    the FE versions are actually very good this year as well. I can barely hear mine. But yes I'd wait until the new cards which 100% totally do not exists may or may not come out.
  10. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    That sounds... Super? :winking:
  11. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The FE version is fine, the 2080Ti (like the 2080) is power-limited rather than thermally limited. Even a hybrid cooler will barely eke out a few percentage points gain before it hits the same power wall. No real need to worry about the cooler unless you;re going to get into voltmodding.
    MLyons likes this.
  12. j17ypr
    j17ypr New Member
    24 Apr 2009
    Thanks for all the help. I did have a thought about the EVGA step up program - buy one now & perhaps upgrade (if) when the new ones come out? Or are we thinking the Super may be a while or a myth?!
    Is the FE the best one then? I wont be overclocking, I'm just a bit worried about the cooling with the HTPC case I'm using. Looking at the prices, there's now another on offer - MSI VENTUS OC (https://www.scan.co.uk/products/msi...raphics-card-4352-core-1350mhz-gpu-1635mhz-bo) which is the cheapest. The EVGA Black Edition seems to have the lowest clock speed, but does the clock speed matter that much?
  13. MLyons
    3 Mar 2017
    There are some grassy Knowles nearby and I sit next to a window but all I'm saying is wait
  14. Anfield
    15 Jan 2010
    This isn't like clothing sizes where you can trust none of the companies to get it right, graphicscards are all at least fine, so basically picking which 2080ti to buy is like arguing over which colour m&m is best.
    But as alluded to above... could well be worth waiting a bit for the new stuff.
  15. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    Blue, obviously. Oh, unless you're talking Peanut M&Ms - or the import-only Peanut Butter M&Ms - in which case yellow. Don't @ me.
    Anfield likes this.
  16. j17ypr
    j17ypr New Member
    24 Apr 2009
    Has anyone done the EVGA step up in the UK?
    Is the 100mhz~ or so clock speed that important?
