Cooling Which 3x120 Rad?
Discussion in 'Hardware' started by Cus_de_Sparta65, 6 Nov 2010.
  1. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    Looking for a decent 3x120 Rad for my i7 build. Is the Thermochill worth the extra £25?
    ThermoChill PA120.3 - 360 Radiator - £65
    SWIFTECH MCR320-QP-K - £40
    XSPC RS360 Radiator - Black -£42
    EK CoolStream Radiator XT 360 - £44
    Hardware Labs Black Ice® GT Stealth Lite 360mm Triple Radiator -£40
  2. bagman
    bagman Minimodder
    18 Apr 2009
    thermochill is the best by far
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    +1, just make sure you flush it first
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Isn't the Thermochill a double thickness RAD while the others are single thickness?
  5. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    I think so. The XSPC RX-series are the same thickness, same performance. Really depends what case it's going in, and how much room/clearance you'll have.
  6. Guest-56605
    Guest-56605 Guest
    What case will you be using?
    And this may help you some -
    http://skinneelabs.com/triplesv2.html
    Altron likes this.
  7. Bloody_Pete
    11 Aug 2008
    My RX360 is running beautifully :)
  8. PocketDemon
    PocketDemon What's a Dremel?
    3 Jul 2010
    Kind of depends whether you're after using water for cooling or quietness.
    Simply that the black ice GTX gives noticably better temps with higher cfm (& rpm -> more noise) fans than the rest... ...though it is even more expensive than the Themochill.
  9. Bloody_Pete
    11 Aug 2008
  10. Cus_de_Sparta65
    24 Apr 2009
    It will be going in a Obsidian 800D for my CPU loop.
    I will be over-clocking but nothing extreme so I would say I am looking for a good compromise between performance and low decibel levels.
    Thanks guys
  11. Bloody_Pete
    11 Aug 2008
    The RX is good as it has quite a wide fin spacing, so it's less restrictive on fans, so you can use quieter fans with it :)
  12. Cus_de_Sparta65
    24 Apr 2009
    Thanks guys, as usual you are a big help. :thumb:
  13. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    i like the black ice stuff myself from hardware labs
  14. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    wide fins = better cooling performance with slow fans = quieter.
    dense fans = better cooling with faster fans = cooler but louder.
