Build Advice Which AMD APU CPU?
Discussion in 'Hardware' started by james_p, 27 Oct 2013.
  1. james_p
    james_p What's a Dremel?
    18 Jan 2011
    Hi,
    I'm looking to upgrade my current setup, new mobo and CPU, and I have narrowed it down to a Gigabyte GA-F2A88X-D3H motherboard for the FM2+ support. However I can't decide on the cpu. It's a choice between the following:
    AMD - A8 5600K @£67
    AMD - A8 6600K @ £80
    AMD - A10 5800K @£81
    I don't play many games these days so I'm not after anything top of the range. An APU also keeps the costs down.
    Will be using 2x4GB 1600 ram from my current system.
    The question is, which one should I go for?? If you have any comment on the motherboard that would be a bonus.
  2. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    50% faster GPU in the 5800k and 10% less power consumption in the 6600K. I'd go for the 5600k if your not planning on gaming.
  3. Thermolance
    Thermolance What's a Dremel?
    19 Sep 2013
    Depending on what operating system you are using.
    if you are using windows 7 I would go with Mucgoos choice. If you are using windows 8(upgrade to 8.1) and go with the 6600K. but both will give you very similar performance.
    You cannot go to far wrong with either of those 2
  4. james_p
    18 Jan 2011
    Thanks guys.
    I was half expecting responses to be the A10 5800K. I seem to recall something about more shaders??
    Not sure which operating system I will run, most likely a windows 8 trial or ubuntu initially.
  5. Thermolance
    19 Sep 2013
    I am not sure how these APU will perform under Ubuntu as I am not sure of the quality of the drivers for them.
  6. Harlequin
    Harlequin Modder
    4 Jun 2004
    what ram will you be using? the APU part loves fast ram - if you use 2133 , the A5800 is faster by quite a bit (256 vs 384 shaders) for gaming
  7. james_p
    18 Jan 2011
    I will have to stick with my 2x4GB 1600MHz ram from my current pc.
    I could ebay them in the future and pick up faster ram but my budget doesn't stretch to that at the moment.
  8. rollo
    rollo Modder
    16 May 2008
    he does mension in his post he is using 1600mhz ram.
    5800k is slightly faster than the later chip but its not a great deal and more depends on game by game basis and resolution your gaming at.
    Nvidia has better Linux drivers one of the few companys to actually support the whole linux thing.
    If your using the APU on AMD side you will probably need to look at a copy of windows 7 or 8. 8 performs better with AMD chips so would be the choice to buy.
  9. Thermolance
    19 Sep 2013
    Rollo
    Much agreed with you there, windows is a better option for the APU
  10. mucgoo
    mucgoo Minimodder
    9 Dec 2010
  11. Harlequin
    Harlequin Modder
    4 Jun 2004
    where do you find a 5870 for £40 from??
  12. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    Sorry 5850.
  13. Thermolance
    19 Sep 2013
    James if you going to do gaming even if it is a little bit you are better of getting a HD6450, HD6650, HD6670 these 3 cards will crossfire with the APU improving fps even more.
  14. james_p
    18 Jan 2011
    @Thermolance I hadn't considered there could be support issues with Ubuntu. I'll look into it.. Cheers
    As for the components, there's a chance I will play games but I the think odds are slim.
    I never mentioned my budget, its around the £150 mark. Can't really go over that which rules out intel and I'm thinking a fm2+ board for future proofing.
