Portable Which Android Tablet for ~£100 - £150
Discussion in 'Hardware' started by yakyb, 8 Sep 2012.
  1. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    Hye guys been a while since i posted
    was wondering if anyone knew which Android tablet would be best for roughly £100-£150
    Looking for internet usage and Light Gaming
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    save a little more and get the Nexus 7. nuff said.
  3. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Or wait six weeks and get the Kindle Fire HD. Same price as the Nexus 7 8Gb, but with 16Gb instead. The only downside: you're tied into Amazon rather than Google.
  4. yakyb
    10 Oct 2006
  5. rollo
    rollo Modder
    16 May 2008
    Tablets in that price range usually have 1 or 2 major flaws. The screen been the biggest one, if I was buying in that budget id want to test them out before purchase.
    The only 2 I'd even recommend or look at would be the ones below.
    Asus transformer pad Infinity Tf700t is in budget and gets high ratings ( £130 ish)
    Blackberry playbook is the best actual tablet for the cash £99 ish, good screen decent battery life, with a bit of hacking you can get native google store support. ( currys and pcworld have the 64gb wifi in stock for £129)
    yakyb likes this.
  6. yakyb
    10 Oct 2006
    where did you get this price?
  7. samkiller42
    25 Apr 2006
    TF700T is the Transformer Primes replacement, so wont be cheaper than it. The Transformer Pad is cheaper, but still £300ish.
    Nexus 7 is well worth a look, it's made by Asus, and has similar specs to the TF201 with it's 5-Core chip, IPS display, and word on the street is a 3G version is being readied. Downfall is the lack of expandable memory, as it's all part of Googles Cloud idea.
    Sam
  8. hoochy
    hoochy Need moar cooling
    16 May 2012
    You can however add additional storage in the form of a USB flash drive and an app. This originally meant you were required to root the nexus, but I think there is an app now that allows you to do some data transfer without rooting. Have a look at the nexus 7 post on BT as there has been some info on this recently.
    Just thought I'd add so you can explore your options :)
  9. rollo
    rollo Modder
    16 May 2008
    Simply electronics ( they have a store nearby not sure they are reliable )was price for Asus one, currys and pc world the other
  10. Flibblebot
    19 Apr 2005
    Simply Electronics has the tablet priced at £400+ on their website. The £130 price is for the docking station keyboard.
    Is still say to the OP, if your budget is £150, stretch another tenner and go for a Nexus 7 of Kindle Fire HD. Go for one of the cheap tablets and you will be kicking yourself.
