Windows Which antivirus?
Discussion in 'Software' started by chrisb2e9, 30 Aug 2012.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I just ordered an SSD and in prep for re-installing my OS I am trying to get things figured out. One of which, is which free anti-virus?
    Have AVG at the moment. Not sure if it's the best though?
  2. GoodBytes
    20 Jan 2007
    I recommend Microsoft Security Essential. Mainly because it provides good protection, is non-intrusive, you feel like you have nothing, and doesn't slow down Windows boot time.
  3. azrael-
    azrael- I'm special...
    18 May 2008
  4. brave758
    brave758 Minimodder
    16 Apr 2009
    +1
  5. Teelzebub
    27 Nov 2009
    Yea MSE it works well and is free
  6. Virus44
    Virus44 What's a Dremel?
    2 Nov 2011
    Malwarebytes antimalware thats what i use :D
  7. Deewon
    Deewon What's a Dremel?
    29 Dec 2010
    Been using this since moving to Windows 7 and never felt the need to swap out. Always recommend it to any friends also looking.
    Only other I would probably vouch for is Avast.
  8. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Using bullgaurd on my desktop and t rend micro on my laptop and had no hassles with either and low on the resources
  9. chrisb2e9
    18 Jun 2007
    Ok, Microsoft it is then!
  10. GeordieGoose
    GeordieGoose What's a Dremel?
    18 Oct 2010
    another +1 for MSE
  11. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    this isnt really anti virus - and real time protection only happens if you buy it, so its not free :)
  12. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    I can also recommend MSE, use it on all my PC's and everyone elses I can recommend it to.
    Very quick, non intrusive and good detection rates.
  13. Shirty
    18 Apr 1982
    I was with MSE until it let through a particularly unpleasant trojan on a family member's PC. I managed to kill it with Avira boot time scan and since then I've moved across to Avira on my own machines as well. I also use Comodo firewall instead of the W7 one simply because it's much more flexible and connections are easily visible.
    Despite my initial misgivings, I have actually found this combination to be very unintrusive and have noticed no slowdown or resource-hogging.
  14. Fat Tony
    Fat Tony Minimodder
    3 Jul 2009
    How about AVG or Avast ? - they're my standard choices on new builds, and I've never had an issue with either.
  15. adidan
    25 Mar 2009
    ^This.
    Avira Antivir on 4 pcs/lappy in my house, i don't mind 1 solitary pop up with update downloads.
    I put MSE on mum's laptop just so it can chug away in the background and she didn't get freaked out. :)
  16. marcjohn308
    marcjohn308 What's a Dremel?
    28 Aug 2012
    Avira is one of the finest anti virus, I used avast & avg previously ,those were big rigid & covering much more space. Avira is better . I am happy with its performance . Really I used norton etc they were also not useful at that point of it
  17. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    +1 for Avira
  18. GeorgeStorm
    16 Dec 2008
    I tend to use AVG, just keep coming back to it for some reason.
    Used avira in the past and liked it.
    Used security essentials on the family pcs, but have since switched.
  19. samkiller42
    25 Apr 2006
    MSE for me, Nice and simple.
    Sam
  20. Harty
    Harty What's a Dremel?
    6 Sep 2012
    I've been using Comodo for a while, hasn't failed me.
