Motherboards Which B450 ITX Board?
Discussion in 'Hardware' started by Arboreal, 5 Aug 2020.
  1. Arboreal
    21 Jan 2011
    Right you 'leaders into temptation', what are your thoughts on the choice of B450 ITX motherboard for dipping a toe in the Ryzen pool?
    Asrock and MSI are simiar prices at £120 ish, with the MSI recommended for its better VRMS, and eth Asrock having Intel gigabit ethernet and a better codec.
    It's now a 3 way fight, as the Strix B450i is now available for only £20 at £140.
    This brings a 2nd M.2 slot, which is welcome in a potentially (very) small case.
    I'll be going inexpensive Ryzen for starters, used lower end 2x00 or 3100 as I have an i5 8400 6 core for photo editing and video crunching. I can't see an 8 core in there any time soon.
    Whatcha think?
  2. RedFlames
    23 Apr 2009
    Asrock.
    You couldn't pay me to have an MSI board.
    Arboreal likes this.
  3. adidan
    25 Mar 2009
    MSI knocked it out of the park with the B450s. No idea on their 5** offerings.
    I have to say mine is one of the best i've owned and the BIOS support has been excellent.
    Very happily surprised.
  4. Arboreal
    21 Jan 2011
    In the red (flames) corner we have a definite NOT MSI; and in the blue, we have an upvote for MSI B450.
    If they have done the same as they did with their Z87 generation boards, I'd be very satisfied.
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I've been a staunch Asus man for well over a decade (probably closer to 2!) but I went for the motherboard in my sig and its been solid for the last 6 months or so. For around £100 its a good board, so I can recomend MSi (can't forget the lowercase i :p) now :)
  6. Arboreal
    21 Jan 2011
    Thanks @Bloody_Pete, the B450 Mortar and latterly the MAX seem to have really swept the board in that chipset.
    I used to use a lot of Gigabyte, and have also been mostly Asus of late; so fairly brand agnostic.
  7. adidan
    25 Mar 2009
    Same here, also have an Asus, had Asus and Giga in the past.
    It seems different companies often do better with different chipsets, there's no rhyme nor reason beyond some seemingly more reliable in general than others.
  8. Bloody_Pete
    11 Aug 2008
    Its probably the ebb and flow of R&D budgets. Do well, gets cut, does badly, gets increased...
    adidan likes this.
  9. adidan
    25 Mar 2009
    Quite possibly, not thought of that.
  10. kim
    kim hardware addict
    10 Jan 2016
    I am "Gigabyte" myself, and I have this baby and I love it but it's just my opinion...:worried:
  11. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Asrock is usually my first choice.
    Also:
    One of us
    One of us
    One of us
  12. adidan
    25 Mar 2009
    I'm still a chunky monkey, need to shed some weight off my mATX.
  13. David
    7 Apr 2009
    I've already told you, WE KNOW.
    TURN OFF THE BLEEDIN' WEBCAM
    :lol:
    adidan likes this.
  14. Spraduke
    Spraduke Lurker
    23 Sep 2009
    I've got the gigabyte aurous WiFi also.
    Not had any problems with a 3600x in it but just check memory compatibility first.
  15. adidan
    25 Mar 2009
    Ah don't worry Dave,the 4k camera will be up and running soon. :happy:
  16. Arboreal
    21 Jan 2011
    Aaaand from left field comes a vote for the really smart looking Aorus from our French correspondent; Bonsoir @kim!
    Quickly seconded by @Spraduke
    I'd heard it overheats and doesn't OC well, but OC isn't really where I'm going.
    I'll check the scores tomorrow, thanks again guys
  17. Arboreal
    21 Jan 2011
    Good boy, get slimmed down to ITX and lose those excess slots :grin:
    adidan likes this.
  18. kim
    kim hardware addict
    10 Jan 2016
    Bonsoir Arboreal :grin: Well, yes, I choosed it for the nice looking it has, but I never noticed overheating, I don't overclock though :rollingeyes:
  19. nimbu
    nimbu Well-Known Member
    28 Nov 2002
    Finally, my votes asrock, put a rig together for a friend over lock down with one.
    Oh but check do you need usb c connectivity for the front panel of your case, not all board's come with a header for one afaik.
    The second M2 is nice on the Asus (it's why I got it) that at the time I scored an Uber cheap refurb on eBay, 110 iirc
  20. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    I have the B450i Strix - more than happy with it and using the 2nd m.2.
