Which budget ATX mobo for Intel Quad Core.
Discussion in 'Hardware' started by Atomic, 3 Apr 2008.
  1. Atomic
    Atomic Gerwaff
    6 May 2002
    The times come for me to upgrade my little Athlon 3500+ system.
    I think I'm going to change back to intel for a quad core system this time, and im well behind in the hardware market these days!
    Which motherboard is decent? I don't need something expensive, just basic and stable. I dont need to OC or have super speed memory just something stable.
    Don't need anything onboard, got a decent gfx card and wireless card already. The only must is that it has got a passively cooled chipset as I run a very quiet system!
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Nobody?
  3. atanum141
    22 Jul 2004
  4. IAmATeaf
    IAmATeaf Minimodder
    9 Jun 2006
    P35 mobo from Gigabyte or Asus would be my advice, just choose 1 that fits your budget and features required.
  5. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    Speaking of which, what is this?
  6. Guest-23315
    Guest-23315 Guest
    If you can reach £85-ish, DFI DK P35-T2RS (seem to be saying this alot today)
  7. Atomic
    Atomic Gerwaff
    6 May 2002
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Have a look at the DS3L if you can live with 4 SATA, no RAID, no Firewire. Under £60 (Scan). Same quality, less features.
  9. rls669
    rls669 i can has dremel?
    15 Mar 2008
    The Abit IP35-E is good value as well and is passively cooled. If you look at the top ranks of quadcores in the HardOCP OC database you'll see a fairly even distribution of Asus, Gigabyte, and various flavours of IP35 boards. I've got the midrange IP35 myself, performance is just fine as you can see from my place in the [H] database (held the top spot for air cooled Q6600s for quite a while), and it's as stable as any board I've had. Having all ram slots filled doesn't affect the OC either.
