Graphics Which card
Discussion in 'Hardware' started by teabag, 3 Dec 2015.
  1. teabag
    teabag What's a Dremel?
    17 Nov 2015
    If using an i3-6100, What graphics card would be best suited with this CPU that would run most modern games (Just Cause 3) but also is cheap and quiet?
  2. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    We really need to know what resolution you game at and also your budget would help.
  3. MrGumby
    27 Apr 2009
    wrong thread :D
  4. teabag
    17 Nov 2015
    Its only a 5 year old 20" Monitor and want cheapest card available that will play modern games
  5. thom804
    thom804 Minimodder
    22 Oct 2009
    http://www.thescreamonline.com/technology/monitor/monitor_res.html for your monitor resolution. Screensize won't tell us much I'm afraid, thought it'll probably be <1920x1080/1200.
    You also say modern games, but what genre specifically? Certain genres tax cards more than others.
    And how cheap is cheapest? Can you afford to spend £200 on a card, or is your budget more aimed at <£100-150?
  6. teabag
    17 Nov 2015
    1680 x 1050 res.
    Game: Just Cause 3
    Cheap means cheap as possible not expensive so cheapest card. Lowest price card i can get away with! lol
  7. thom804
    thom804 Minimodder
    22 Oct 2009
    Well, given that JC3 is currently running into problems with a variety of cards, I'd hold off purchasing anything until the bugs are fixed.
    Other than that, I've read that some people are playing it fine at 1920x1080 with an AMD 380 (or Nvidia 960 as approximate equivalent) which are about £180 for a 4gb version.
    Personally, I'd get as good a card as you can afford and a bigger monitor to match to make the most of these new games.
    Get some savings up to about £4-500 and you can get a decent combo of monitor and gfx for that money.
  8. teabag
    17 Nov 2015
    Anything cheaper Graphics wise?
  9. thom804
    thom804 Minimodder
    22 Oct 2009
    Get an Nvidia 950 for £125.
    Benchmarks just don't cater to the resolution you play at any more so there's barely any comparison to be made. It might run well, it might not.
  10. MrGumby
    27 Apr 2009
  11. MrGumby
    27 Apr 2009
    Anything sub £120 is already pretty dated.
    The 750Ti 2GB can be had for £87. Don't know how well it will stack up in latest games though.
  12. rollo
    rollo Modder
    16 May 2008
    Badly, it's below just cause 3s minimum requirements first and foremost.
  13. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    buy cheap, buy twice
  14. Vault-Tec
    30 Aug 2015
    This plus a couple more. These low-mid range cards are replaced every other month and used to make me chase my tail.
    Then I learned to invest a bit more in the mid-high end bracket and I found that they lasted far longer. As an example the Radeon 290. It's since been re-released with more VRAM (mostly useless atm if ever?) but it primarily the same card.
    The only GPU purchase/s I have ever really regretted was a pair of Titan Blacks (along with the rest of the £3500 I completely wasted).
  15. teabag
    17 Nov 2015
    Thanks guys. Got to have a think then. A mate has offered me his GPU for free but waiting to see what spec it is. Once i know i will post details on here and you can advise. Ta
  16. teabag
    17 Nov 2015
    GV-N460OC-768I
    Any good?
  17. Harlequin
    Harlequin Modder
    4 Jun 2004
    GTX 460 768mb - if the 750 cant play JC3 then the 460 has less chance....
  18. teabag
    17 Nov 2015
    so, dont use the card my mate is offering?
  19. ripmax
    ripmax Minimodder
    8 Apr 2010
    If you're wanting a cheap card that will play JC3, a used 670 is your best bet, if you cant afford something like an r9 380/gtx 960
  20. teabag
    17 Nov 2015
    Ok, thanks people
