Graphics Which card
Discussion in 'Hardware' started by teabag, 3 Dec 2015.
  1. Harlequin
    Harlequin Well-Known Member
    4 Jun 2004
  2. Vault-Tec
    30 Aug 2015
    I've seen quite a few 680s and 7970s sell for that or less tbh. IIRC a 680 Power Edition sold last week for £85 inc.
    670s are worth more like £60-£75 depending on model etc.
  3. thom804
    thom804 Member
    22 Oct 2009
    Seriously, you seem to be rebuffing advice all over the shop.
    The majority opinion here is to save and buy the best you can.
    You might get a card that can just about play JC3 at 25-30fps, but next year when another game comes out, then what? You'll come here asking for another cheapo card that can play that game.
    Spend £2-300 on one card and that'll serve you well enough for the next 3-4 years unless graphics technology becomes drastically intensive, which is won't.
    Better that than spending £100+ per year on cards that just don't cut it in any way.
  4. teabag
    teabag New Member
    17 Nov 2015
    Not rebuffing anyone. Money is a factor. I cannot spend £200 or anywhere near that as much as i would love to.
    2nd hand would be fine but i would never buy from ebay.
  5. thom804
    thom804 Member
    22 Oct 2009
    Then save it up. If you can spend £100 one month, surely you can spend more the next month if you save it up? By that time anyway, JC3's bugs will be on the way out (hopefully), and the price may have dropped a few percent.
    Better yet, wait out the year and save a lot, an JC3 will be more than worth the purchase.
    Also, you're better buying from eBay than somewhere like Gumtree or Craigslist. At least you can get paypal protection if the card turns up a dud.
    The other option is to get a refurb'd card from Scan/Overclockers etc. It'll be a second hand card that comes with a shortened guarantee, but it should get the job done.
  6. teabag
    teabag New Member
    17 Nov 2015
    I want something sooner
  7. teabag
    teabag New Member
    17 Nov 2015
    Anyone?
  8. Harlequin
    4 Jun 2004
    what you are asking and your budget are 2 different things ; if you want to buy a card from the market place , you need more posts
  9. teabag
    teabag New Member
    17 Nov 2015
    I know that. Not really looking for 2nd hand
  10. ripmax
    ripmax Active Member
    8 Apr 2010
    There is nothing you can buy new for less than £100 that will play JC3.
  11. rollo
    rollo Well-Known Member
    16 May 2008
    Theres a pretty short accurate answer for ya.
  12. teabag
    teabag New Member
    17 Nov 2015
    £150 would be my upper limit
  13. thom804
    thom804 Member
    22 Oct 2009
    You can get some decent cards 2nd hand that will run JC3 for £150. You just need to make a decision on whether or not you're happy with 2nd hand.
  14. teabag
    teabag New Member
    17 Nov 2015
    What i meant was i wouldnt buy from Ebay
  15. thom804
    thom804 Member
    22 Oct 2009
    So where exactly would you buy second hand from then? Because as I've stated earlier, at least with Ebay, you get buyer protection.
  16. Vault-Tec
    30 Aug 2015
    Every second hand GPU I've bought from Ebay so far has been a bake job. I'll admit they were quite old (as I only needed them to flash a bios or what not) but yeah, not cool.
    I would buy a second hand GPU from Ebay but only if it were Gigabyte or EVGA and still well within warranty.
  17. teabag
    teabag New Member
    17 Nov 2015
    I know but i hate ebay.
  18. Spigsy
    Spigsy Member
    28 Sep 2009
  19. teabag
    teabag New Member
    17 Nov 2015
    Thanks, will check it out. I will be changing my monitor after Christmas so will have a different res. Max i will be looking at is a 22" Monitor
  20. rollo
    16 May 2008
    Most 22inch new monitors are 1080p.
