Ok, decided to get a new case, been looking at either the Lian-Li PC-A71B seen here or the Lian Li PC-A77B seen here Trying to decide which one is better. I have about 350 to spend on case and mods, I am looking for duel loop deffo, possibly triple loop. One triple rad would defiantly be going into the roof either way, not sure about the rest though. What I’m asking is: 1. Which case for duel loop and why 2. Is it possible to triple loop either effectively (Apart from simply a PA120.1 on the rear fan) and how? 3. Which one do you think would look better in bright red externals, black internals, and red highlights? EDIT: Any other case suggestions around that price range would be good either
Obsidian Series 800D from Corsair, Just look at it... Case Available end of June, Start of July. look at the virtual tour below: Obsidian Series 800D
Erm, it's box shaped like any other. What do you mean? I'd pick a big tower Chieftec instead of a lian li, it's a lot less cluttered inside, not to mention less expensive and more massive. p.s. i'm also anticipating the Obsidian, it's amazing.
I mean the internal layout, its a lot more compartmentalised to make it harder to position anything bit like a PA.120.3
