i think they are both look ugly, personally i wouldnt even buy either for $10 though i think the super lanboy inst as ugly as the other one, so i would proberly pay $7 for it... lmao
I am going to change the color in black. Are all parts in the front panel removeable LoneArchon? Gimme more info
aluminum chieftec matrix if you want an aluminum case for <100, I suggest the Coolermaster Praetorian http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-035&depa=1 It's just above 100 (108) but just scrape together your pennies and you have a really nice high quality coolermaster aluminum case.
The rear part is strange. One 80x80 fan for so big place. If i take this it will be moded. It will be easy to install 2 80mm fans with aqua-computer grill You know it http://www.aqua-computer.de/prodimg/nd_products/b120_500.jpg
Hey guys i need your opinion again. I am between two new cases and i am collecting opinions and info about them. Anyone have any? Here are the links 1. http://xoxide.com/v-tech-x-focus-7103h-black.html 2. http://xoxide.com/v-tech-x-focus-7104h-silver.html They are almost the same but..If i take any of them i will cut the side panel *where the filter is and put some plexi. I will also remove the Screw-less drive bays kits because they are ugly and try to make new or we will see..anyway hit me with your opinion about them Thanks
get a lian li pc-60 . its $95, so its a little expensive, but it has great modding potential but looks great on its own.
Thats a lot of cases XOXIDE have. I dont think much of your first choices, after looking through the range how about one of these: Soprano Black Soprano Silver Or this. I reckon the mod potential is great, It looks mean and its cheap as chips! Berserker Good Luck EDIT: For the sake of $9 why not buy this: Kingwin (Lian Li quality without the price)
