Modding which case?
Discussion in 'Modding' started by foundsoul, 15 Dec 2004.
  1. foundsoul
    foundsoul What's a Dremel?
    24 Aug 2004
  2. belier
    belier What's a Dremel?
    13 Aug 2002
    My vote would go towards the Lian Li case. I've not been overly impressed with ThermalTake cases in the past, and Lian Li is as solid a case as you can get.
  3. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    Both as good, I would suggest the Tsunami because of its 120mm fans, but if you're going for looks, its definitely the Lian-Li!
  4. Gascan1888
    Gascan1888 What's a Dremel?
    15 Dec 2004
    Go with the Thermaltake, it looks much better then the lian li, and has free shipping. if it dosnt fit your cooling requirements you could always (GASP)... mod it :rock:
  5. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    Thermaltake to used and moded alrdy i would go with the lian li but that is just my pick. You should decided yourself but sometimes others opinions are what you need.
  6. Shrapnill
    Shrapnill What's a Dremel?
    5 May 2002
    Lian Li.
    The Tt has an ugly window, ugly plastic crap inside, ugly side fan, restrictive bay door, and if the mobo tray is removable, its that kind thats still a PITA.
    Go with the Lian Li. I own 2. Love em.
  7. dannyqball
    dannyqball What's a Dremel?
    22 Apr 2004
    I agree with Shrapnil, besides I think you have more modding options with it if you later on wanted to start chopping it up to personalize it.
  8. fuksis
    fuksis What's a Dremel?
    16 Dec 2004
    o with Thermaltake VA3000 Dream Tower Black Tsunami.
    I think it is exelent looking case wit no job needed ;)
  9. belier
    13 Aug 2002
    :eek: How UnModly! :eek:
    :D
  10. fuksis
    16 Dec 2004
    lol i know but it is a good looking case with none mods needed, but i did not say i don't want to see it cut a part ;) :dremel:
  11. CyberSol
    CyberSol 1337 Pants
    18 Oct 2004
    what is your price range? can we make other suguestions?
    like the wave master or somthing
  12. Groovedude
    Groovedude Minimodder
    29 Aug 2003
    Yes thats a nice case and has recent review of the blue edition on the front page..
  13. Howitzerflagz
    Howitzerflagz What's a Dremel?
    24 Apr 2004
    i like the cooler master but the TT is more aggressive !! go to TT! !!!! :rock:
