Equipment Which Circular Polarizing Filter?
Discussion in 'Photography, Art & Design' started by phinix, 25 Jun 2013.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Guys, I'm planning a nice trip to Paris with my Panasonic 20mm 1.7 lens and wanted to buy some Circular Polarizing Filter, 46mm.
    Which one is does what it supposed to?
    Hoya, Hama?
    Hoya is like £25, so was looking for something cheaper, but still doing its job. I read some review of cheaper ones and people complain that they are not ideal.
    Is it worth pay £25 for one?
  2. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I had a Sigma EX circular polarizer and it was excellent, but they are very pricey. You might be able to pick one up on ebay second hand for a reasonable price. Definitely avoid the cheaper ones... they are just a waste of money. There's a reason you pay around £100 for a good quality polarizer: they work!
  3. phinix
    28 Apr 2006
    100quid? Well, now £25 for Hoya doesn't sound that bad...;)
  4. wyx087
    15 Aug 2007
    I am using Hoya HD 77mm CPL. They do work and they do work very well.
    Tower bridge by wuyanxu, on Flickr
    I have tried a ebay value one for 52mm, they don't work as well and the glass is now loose.
    You can go cheap on the rocket blower or the camera strap, but you don't want to go cheap on the filters.
  5. phinix
    28 Apr 2006
    I found this one on ebay, looks genuine, what do you think?
  6. Nexxo
    23 Oct 2001
    I use a Jessops Digital Pro. Does exactly what it says on the tin.
  7. whisperwolf
    whisperwolf What's a Dremel?
    1 Sep 2004
    Marumi DHG Super, great polariser, mechanically sound, good coatings, and normally available for a lot less than the list price, try here, but its going to hit at around the £40. a Cpl is 2 pieces of glass and cheaper versions tend to flare and cause Vignetting. they can also be a pain to rotate, remove from your lens and the glass gets loose quickly.
  8. phinix
    28 Apr 2006
    I'm getting Hoya one, found someone who has unused one for sale on TalkPhotography.
    Will see how it's gonna work with 20mm Pana pancake...
  9. Xir
    Xir Modder
    26 Apr 2006
    The cheaper HAMA ones were plastic.
    So i got the Hoya one.
